Re: Electrical Problem: headlight switch turns sta
DrEntropy said:
ISTR a circumstance just about like AlanT recounts. At about the same year, too. No diagram in front of me now but there was feedback tru the lighting circuit engaging the starter. A thorough inspection of the connections and a diagram are indeed the only way to sort this, agreed. And likely diode replacement.
I do have a wiring diagram in front of me.
How does diode failure in the service counter light circuit or the brake warning light circuit affect the headlamps and taillights?
The circuits are independent of each other.
This what happens when the diodes fail.
Service counter lamp diode:
Service counter reaches a specified mileage point and closes illuminating the lamp. If the diode fails, feedback from the green/pink wire energizes the white/red wire causing the starter to engage. The green/pink wire gets power from the green circuit which gets power from the white wire circuit.
Brake warning lamp diode:
The brake warning lamp is illuminated when the handbrake handle is pulled up closing the circuit between the green wire and the green/orange wire. If the diode fails, then feedback from the green/orange wire energizes the white/red wire causing the starter to engage.
Removing the diodes and insulating the unconnected terminals will have no effect on the electrical system with the following exception, the bulb test feature when the ignition switch is in the start position will be removed.
The exterior lighting circuits are completely independent of the white/red wire circuit and the green wire circuit.
Exterior lighting is wired as such;
brown wire > headlight switch > branches to two circuits,
1.) the taillights, dash lights, and marker lights - red/green wires, red/white wires, and red wires.
2.) the headlights - blue wire, blue/white wires, and blue/red wires.
If everything is connected the way it is suppose to be, the only way I can see that the exterior lights would have any effect on the starter circuit would be that if the insulation on one of the white/red wires and one of the wires in the lighting circuit were damaged allowing the lighting circuit to intermittantly energize the starting circuit.
If someone had worked on the wiring under the dash, then who knows without looking if a couple of wires are cross connected, especially the white/red wires and the red/white wires.
