Even though we haven't had an accumulating snow in Maryland yet, I decided it was time to pull Baby Blue off the road for her winter overhaul. I already knew a brake master cylinder replacement was on the menu, but on the last drive, it was apparent the clutch master is leaking, too. I actually could deal with the leaks and just add more fluid if they weren't leaking onto the pedals and my shoes. Nothing quite like going for the brake or clutch pedal and having your foot fly off of it from slipping on the fluid.
Other items are replacing the exhaust manifold gasket, which didn't seat properly the last time I replaced it. Is RTV an option for the manifold gasket to help hold it in place? I did not use any sealant last time and that put me in my current situation. I'm going to take a stab at the headlight harness upgrade and try to preserve as much of the original wiring as possible and just tie in the harness where I need to. I also picked up one of the Chinese made generators as the current Lucas one also has bearing issues. I figure this gives me some time to get one or both of my stock generators properly fixed.
