TR2/3/3A 60 TR3 Mounting some parts
Tinkerman
Afternoon:
Where on the engine does the front lifting eye mount and where does the torque reaction arm mount? Found no info in the manual or other sources.
Appreciate any info.
Thanks, Tinkerman
Banjo
the lift eye mounts to the back side of the timing plate on the left side of the motor, where it sticks out from the block. As for a torque reaction tube, that's gotta be an add-on thing.I don't remember seeing a torque tube on any TR3s unless it was a modification. of course I could be misunderstanding what you mean by "torque tube"
karls59tr
Bronze
I think only the TR4's had the torque reaction tube. I'm wondering if this was an upgrade by Triumph for the new TR4's? Which begs the quetion: Would they stop some kind of powerplant torque wind up on the TR3's? I havent noticed any problems in that regard but maybe thats because I'm just used to the way my 3 drives? Karl
Harry_Ward
Karl,
You are correct TR4 for the torque reaction arm. Usually find them on souped up 3's when used on the race track. Tinkerman increased the cyl. bore and is probably looking to do some high performance mods which he feels may require the torque arm. Just a guess though.
Tinkerman
Tinkerman
Good Morning:
Thanks for the comments,neither item is shown in the Stanparts catalog, but as Harry pointed out, are in the Moss catalog. Now that I think about it I may not even have the torque reaction arm. Have to go looking for it. I saw it in the catalog and figured that since I have a post 60000 car it would probably be on there. And yes I have done some internal engine modifications so it might be good to have.
Thanks, Tinkerman
Don Elliott
With a normal TR3A engine, there is no torque reaction stop. If your front motor mounts are old and soft, the engine will torque and the front air filter will hit the inner front wing when the engine rotates due to the torque and the soft mounts.
That Moss page covers all TRs up to the TR4A and shows all the parts for all these variations.
MDCanaday
There is also a lift strap that is supposed to be located on the rear head bolt on the right hand side. It presents a problem to the average machanic so it is often lost.The problem?? The exhaust manifold had to be installed before the head was torqued down,not a common procedure. The torque stop thing was fitted to the 4 to help the under designed motor mounts last. A better fix is to use the tranny mount from a volvo 244( 1970ish) nearly identical in appearance, but 25% larger in diameter.Never did the math, but this should be close to twice the strength.
MD(mad dog)
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
Scotsman TR2/3/3A How to Mounting Oil Cooler on TR3 Triumph 3
Tinkerman TR2/3/3A 1960 TR3 A Hood stick mounting point? Triumph 11
O TR2/3/3A TR3 Body Mounting Hardware Triumph 1
T TR2/3/3A TR3 floor / frame mounting point question Triumph 13
Kleykamp TR2/3/3A TR3 Generator mounting issues help needed Triumph 4
T TR2/3/3A Radiator mounting bolts on TR3 Triumph 16
K TR2/3/3A Mounting TR3 Body to frame with front apron on? Triumph 4
O TR2/3/3A TR3 Windshield to Scuttle Mounting Triumph 1
M TR2/3/3A TR3 steering column mounting question???? Triumph 2
RedTR3 TR2/3/3A TR3 Oil Breather Mounting Triumph 6
luke44 TR2/3/3A TR3 Rad Mounting Triumph 6
mountainman TR2/3/3A TR3 Rear Fender Mounting? Triumph 4
K TR2/3/3A TR3 front end..mounting wishbone near steering box Triumph 9
P TR2/3/3A tr3 wiper motor mounting Triumph 7
Tinkerman TR2/3/3A TR3 Master Cylinder Box Mounting Triumph 9
CraigLandrum TR2/3/3A Stock TR3 Fan mounting Triumph 9
H TR2/3/3A TR3 Generator Mounting Bolt Size Triumph 5
martx-5 TR2/3/3A TR3 Radiator Mounting Triumph 10
martx-5 TR2/3/3A TR3 Body Mounting Triumph 1
PeterK TR2/3/3A TR3 Hardtop mounting brackets Triumph 13
W TR2/3/3A mounting aeroscree on post 60000 tr3 Triumph 4
JFS TR2/3/3A Mounting fenders on TR3 Triumph 5
S TR2/3/3A tr3 valve spring compressor Triumph 1
