TR2/3/3A TR3 Generator Mounting Bolt Size
Hatman
Anyone know the size and length of the two generator mounting bolts for a 1959 TR3 (<60001)?
Thanks in advance.
Mark
Geo Hahn
Hopefully you'll get an answer from someone who knows (I don't off hand) but thought I would mention that at least in the case of the front bolt, I don't think a hardware store bolt of the correct thread and length is quite enough -- I recall that bolt has a shank on it to prevent the threads from chewing up the generator front plate. Using a full-thread bolt may seem to work but can be a problem (literally) down the road.
Tinkerman
Call TRF, they can tell you. I agree with Geo, you won't find them locally. I bit the bullet and bought them from one of the big three.
Tinkerman
TR3driver
Great Pumpkin - R.I.P
Same thing is true of the rear bolt; the part that contacts the generator needs to be a smooth shank. However at the rear, you can just use a bolt that is long enough to have the right length shank. Original part numbers were 59115 (front), 113094 (rear). TRF seems to have suitable substitutes listed.
vivdownunder
And carefully check the thread inside the generator front pedestal mount, as they chop out, and if so, a new bolt doesn't hold for long.
Use new spring washers on both bolts, as there's a lot of vibration there, and if the rear bolt comes loose, the generator backplate often snaps.
Viv.
Kleykamp TR2/3/3A TR3 Generator mounting issues help needed Triumph 4
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
F TR2/3/3A I just installed a rebuilt C39 Generator on my TR3 Triumph 11
5 TR2/3/3A TR3 electrical problem ignition or generator??? Triumph 12
mgedit TR2/3/3A TR3 Generator ... not working Triumph 12
S TR2/3/3A Generator and voltage regulator on a tr3 Triumph 17
K TR2/3/3A TR3 polarizing the generator Triumph 4
CJD TR2/3/3A It's Alive!...TR3 Generator & Rad Questions Triumph 16
O TR2/3/3A TR3 Generator Not Charging Triumph 3
K TR2/3/3A TR3 Generator/ Fan Belt Issue Triumph 12
6 TR4/4A TR3 [TR4?] Generator available??? Triumph 10
K TR2/3/3A TR3 generator color? Triumph 4
K TR2/3/3A Generator light stays on? TR3 Triumph 4
mountainman TR2/3/3A TR3 Generator Question Triumph 12
A TR2/3/3A TR3 generator mount bolt size Triumph 4
T TR2/3/3A Rebuilt generator on Rock Auto for TR3/4 Triumph 4
CraigLandrum TR2/3/3A TR3 Generator Springs? Triumph 3
M TR2/3/3A TR3 New Generator Triumph 6
PeterK TR2/3/3A tr3 generator pop Triumph 3
S TR2/3/3A TR3 Generator kaput Triumph 18
