CJD
Well, my son and I got the old girl running last night. It was really a surprise...most rebuilds I've done crank for a while before coming to life. She just went Kachug KaVroom! Still going through adjustments, so haven't taken her out on the road yet.
A couple items came up that I need some assistance with...
There is a small leak in the radiator, right at the top on the filler neck. I'm sure we can fix it in place. The question is, what type solder and flux do you guys recommend. Standard, or the harder silver?
Second, the generator is all rebuilt with new brushes. I noticed while revving the motor that the brushes flash bright sparks at high speed. I mean like movie projector bright! My generator experience is about nil...so, is this to be expected until the brushes conform to the armature? The output at first start was very low (gen light would only go out when I manually closed the cutout breaker), but after a few minutes running the output is noticeably higher (gen light goes out on it's own now.)
I still have a lot to go on the restoration...wheels, side screen and top...but I truly want to thank all of you for your help in getting the old girl back to life!
Thanks!
John
Thanks!
John
