TR6 It's alive! [kind of]
sammyb
Dropped by my garage today to do some fixing of appliances at the rental house next door. (By the way: don't try to replace a burner switch without disconnecting from power. That was one major-league shock!!!) After doing my handy man routine, I decided to try to get the TR6 actually running. Shot some starter fluid in there, and it actually ran on the starting fluid. Since I drained the fuel system and refilled with a few gallons (although I didn't drain the float chambers, which really needs to be done), I didn't know if the fresh fuel was being pulled. To test the strength of the fuel pump, I pulled the line at the rear carb and turned the key. She's pumping nicely!
Tomorrow I'll go pull the float chambers off and clean them of the very old and turned fuel. Since we know we have spark, air and fuel, provided the carbs are pulling the fresh fuel in the right amounts, this thing should run as designed in no time.
Won't drive it until I rebuild the clutch slave, though. It's leaking. Rebuild kit is on the bench and my air compressor is already hooked-up and at the ready to push the piston out if it's sticking. Not my first rodeo or Triumph clutch slave rebuild.
S
sammyb
No, Tom, I haven't...but I planned to if needed. They seemed to be working freely with oil still in the dashpots. The car was stored with less than a gallon of fuel in the tank, so that went south really quickly. I'm going to clean them today and see what I find. I might get lazy and try to just drain the float chambers and see if the new fuel will finally get it started. I always seem to get to a point where if I don't have to undo all the nuts and linkages if I don't need to, I try to to avoid it. Of course, it usually winds up that doing it the right way winds up quicker in the long run! ;)
mctriumph Morgan comes alive Other British Cars 2
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
Griz It's Alive! Austin Healey 20
Jim_Gruber Bugsy is alive and went for his first real drive this afternoon. Spridgets 9
Steve If you need a smaller SUV that will keep you alive... Rover / Land Rover 2
AngliaGT 1974 Midget - It's ALIVE!!! Spridgets 7
Marvin Gruber TR5/TR250 Its alive! Triumph 10
rjc157 I Donald were still alive Austin Healey 15
Tinkerman It's Alive, It's Alive! Triumph 13
T Since 1988 the car is alive Triumph 1
CJD TR2/3/3A It's Alive!...TR3 Generator & Rad Questions Triumph 16
Banjo The V-dub is alive!!!! Other Cars 12
TraceZ Our sprite is ALIVE - video inside!! Spridgets 7
Tabcon IT'S ALIVE! ... See it on You Tube Triumph 16
R MGA ITS ALIVE! MGA Started After Sitting 4 Years MG 1
jsfbond It's alive!!!!!!!!! Triumph 7
TR6oldtimer TR6 The TR6 engine is now alive Triumph 4
T Woo-Hoo! It's alive!!!!!!!! MG 18
DNK HEY SKIP, IT'S ALIVE Triumph 28
c5racer It's Alive! Spridgets 14
Darwin IT'S ALIVE!!! IT'S ALIVE!!! Triumph 12
T It's Alive!!!! MG 8
davester It's Alive!!!! MG 7
angelfj1 She's Alive Triumph 22
CraigLandrum TR2/3/3A 1959 TR3 is alive! Triumph 24
M ITS ALIVE!!! after 35years Triumph 13
martx-5 TR2/3/3A TR3 Is Alive Triumph 12
T IT's ALIVE!!!!!!!! MG 2
G She's Alive!!!!!!!! Triumph 17
drooartz It's alive [sorta]! British Motorbikes 4
AltaKnight It's alive Triumph 10
S I'm still alive!! Spridgets 12
Morris It's Alive!!! [again] Spridgets 8
B Its Alive!!! Spridgets 8
mrsprite It's alive! Spridgets 46
B It's alive! Spridgets 8
YankeeTR Our hobby is alive and well... Triumph 0
M it's alive !! Triumph 5
philman yipee! It's alive! Triumph 13
milemarker60 TR6 I drove the TR6/M3 last night!!! It's alive. Triumph 20
T It's Alive, It's Alive I Tell You Triumph 10
77_MG_Midget It's ALIVE... well, sort of Spridgets 0
vping IT'S ALIVE!!! MG 7
jaybird Video: "It's Alive!!!" MG 23
S Corvette Crash -- lucky to be alive. Other Cars 12
M she's alive!! MG 3
A It's Alive! Triumph 1
Y She is alive finally Austin Healey 2
George Zeck It's Alive !!! [Thanks to all !!] Spridgets 10
bighly It's alive !!! 3.8 Liters Austin Healey 2
