TR2/3/3A 3A radiator shroud
newmexTR3
Happy Friday all.
Apparently the pope has brought the good weather with him to new york city, because it is gorgeous here today. Wish i had the car to go take a drive!
So I bought one of those cardboard TRF radiator shrouds. I've realized I have no idea how to mount it correctly. If anyone has one mounted, could you share some photos?
Cheers,
Gavin
Twosheds
Don!
Photos please!
Don Elliott
I bought mine 20 years ago. TRA say it should be body colour, so I sprayed it black. It came as 3 pieces. One left, one right and a small piece that goes over the top of the rad. Mine came with instructions and some brass clips like you would use for holding 3-hole loose leaf pages together. I slid these through the holes provided to make it all into one piece.
You don't need to drill any holes in your TR. Remember that these were an after-thought from S-T about mid 1958 when all the TR3A owners started to complain that they were all having over-heating problems. So they were made cheap and had to be easy for the dealers to install this give-away fix to satisfy the customers.
First you will have to remove your grille. It'll take you less time than normal because you have no bumper. You slide the air deflector into the grille opening and up so that the top is above the rad and fit the two sides close to the sides of the rad. There should be crease lines where you do this along both sides of the rad. Also there should be a crease at the bottoms of both sides, which you bend flat - towards the grille opening. These wedge against the floor of the rad pan. There are two large holes about 1 to 1-1/4" diameter in the side pieces which line up with the holes where normally the upper bumper supports go. Use a bolt and some large flat washers on each side here if you are not going to use the upper bumper supports.
John - I don't have any photos handy and while my deflector is out and sitting on my workbench right now, I feel lazy with all this heat and sunshine.
MGTF1250Dave
Aloha Gavin,
Don's description is very good. If the shroud is matches the body color and you don't have to paint it, I would still recommend something like Thompson's water seal. Paint or a sealer will prolong the life of the shroud.
Before installing it in the car, pre-bend the creases so it is easier to unfold.
Twosheds
Don, your words are as eloquent as any photo.
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
longbridgehealey Radiator shroud Jaguar 0
af3683 TR2/3/3A Radiator Air Deflector / Shroud Triumph 31
Patrick67BJ8 Kilmartin Radiator Fan Shroud Austin Healey 4
bridgener Radiator Shroud Question Austin Healey 9
Brosky TR5/TR250 Sweet TR250 in NY, but where is radiator shroud?? Triumph 14
R Radiator shroud recommendations MG 18
P Radiator shroud Austin Healey 8
K radiator fan shroud Triumph 21
T Radiator shroud Triumph 7
T Radiator Shroud Triumph 17
I TR6 radiator shroud for TR6 Triumph 3
P Radiator Fan Shroud [aka finger protector] Austin Healey 1
A TR5/TR250 TR-250 Radiator Shroud Triumph 5
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
J BJ8 Radiator Fan Austin Healey 12
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
R TR6 Radiator protection shield differences Triumph 0
K For Sale TR3 Radiator Guard Triumph Classifieds 0
S For Sale Mg tf new radiator shell-slats-false nose-emblem MG Classifieds 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
edkap2002 TR6 lower radiator hose fitting Triumph 2
nevets Radiator Overflow Tank Austin Healey 23
K TR2/3/3A Radiator coolant level? Triumph 5
K TR2/3/3A Radiator drain tap? Triumph 4
D TR2/3/3A radiator overflow restrictor Triumph 9
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
G 100/6 Radiator cross member Austin Healey 6
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
S TR2/3/3A and the radiator was leaking. Triumph 7
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
