TR2/3/3A Radiator Air Deflector / Shroud
af3683
I recently became aware that I'm supposed to have a fiberboard radiator air deflector / shroud on my TR3B. I've read some of the prior posts from folks who have recently installed them and have a few additional questions. I assume these air deflectors are supposed to direct all of the air entering through the grill directly to the radiator, and not around it, in order to assist in the cooling process. I would appreciate knowing
if folks that have installed these air deflectors have noticed a big difference in cooling? Do you have a preference between the TRF 3-piece version, and the Moss version which appears to be one piece. Finally, have you primed and painted the air deflectors? Thank you.
Art
mrv8q
Hey, Art, I bought the TRF shroud 8 years ago, to replace the tired original shroud. Don't know about any difference in temp, but the TRF shroud has held up very well; though it's never seen rain. I didn't take Geo's advice to prime/paint my shroud.
HTH!
Geo Hahn
I find it is hard to tell 'seat of the pants' which things I have done really help with cooling -- I just do lots of stuff and the net result is good.
I have always used the assembled version of the shroud (apparently the Moss version) which is 3 pieces but comes already riveted together. The fit was fine.
I painted the front body color (that is what was original I believe). I did something to the back side -- black paint? Thompson's Waterseal? What ever you do I would not leave it unfinished as water will not be kind to bare fibreboard.
af3683
af3683
I received my radiator air deflector / shroud and was examining how to approached putting it on the car. It looks like the only way to possibly remove the grill (without the added work of removing the bumper) might be to remove the carriage bolts that hold the overrider support tubes to the end of the overriders, then remove the washers and nuts holding the overrider support tubes to the wheel wells, and then remove the support tubes with the carriage bolts in them through the grill. Can anyone tell me if I'm correct or am I missing something. Thank you.
Art
Got_All_4
They are supposed to be painted the body color. I just took mine out a couple of months ago after it has been in the car for 30 years and it has held up well for being paper. However I am going to replace it and some how seal the edges because the old one the layers on the edges are separating.
TR4nut
Art
Art-
That works fine - I did exactly that when I installed a pusher fan. Support tubes removed first, then grill, no problems at all.
Randy
toysrrus
Art-
Randy
Randy, Did you install a "Pusher Fan" on a TR3 or 4? If it was a TR3; I`m guessing you somehow got it thru the grille opening etc etc without removing / moving the front apron? How did you do that & what size was the fan?
Thanx, Russ
TR4nut
Russ-
Yes I did on my 3A - sorry, I bought the fan so long ago I'm not sure of the size at the moment but with a little detective work I can let you know. I used a trick Geo showed a long time ago in terms of mounting it - I made up some angled rod to use as clamps and ranthe rod along the side of the radiator to secure the fan - fan was big enough that I could do that. And yes, if you pull the grill you can install the fan. I was also able to keep the deflector although I removed it during the fan installation.
Randy
Geo Hahn
...I used a trick Geo showed a long time ago in terms of mounting...
Redux. I used a 12" fan, the pics are of the TR4 but sis the same thing on my TR3A:
Decapitated and bent some bolts:
Used short lengths of fuel ine for cushioning:
Had to oval out the holes in the mounting tabs to allow the bolts to clear the side of the radiator:
Tabs snapped into place on the 12" fan:
Fan mounted to radiator:
You will be working in tighter quarters inside the TR3A bonnet, but the fitment is the same. I think you will want to mount the fan before you mount the shroud.
The fan you use may differ and you may find a better variation of mounting -- what I have shown is just one way to mount one particular fan.
toysrrus
Hey Geo;
Thats some great info & pics!!!!
Thanx, Russ
toysrrus
Geo,
It appears that your "Elec. Fan" is a "Universal Fit" with several mounting areas for the brackets; Correct?
I`m looking at a bunch of "Universal Fit"; Push/Pull, 12Volt, 12" Dia fans on ebay for about $26.00 shipped (Cheap)!!
Some show "Flat" blades & some show "Curved" blades. I would think the "Curved" blades would be a better but I`m looking for suggestions.
Also; They show CFM ranging from 1100 upwards of 1750. What are some suggestions relative to the CFM?
I`ll get this darn thing "Dialed-In" sooner or later. I`m simply looking for the "Easiest" way to make it happen!!!!
Thanx Again,
Russ
Geo Hahn
It appears that your "Elec. Fan" is a "Universal Fit" with several mounting areas for the brackets; Correct?...
Yes, just a cheap one from a FLAPS:
I do not know the CFM.
Mine had curved blades but I don't think that is a big deal either way -- if fact you may be better off with flat blades as you will be reversing the rotation to use the fan as a 'pusher'.
Got_All_4
If the blades are straight and being DC current I think you can reverse the polarity to reverse the air flow without any problems.
toysrrus
My TR is "Positive Ground".
What does that mean relative to wiring a "Flat" bladed Elec Fan? Pos. to Pos?? Pos. to Neg??
Thanx, Russ
PS: It will be used in the "Pusher" function mounted on the front of the Rad.
Geo Hahn
I think you will want to wire positive to negative as you are reversing the rotation (for a pusher) compared to the usual set-up.
The unit is usually all plastic so not grounded as such -- you can easily connect it temporarily to confirm which way it is blowing.
When I had one I powered the hot (negative, fused) side and ran the ground side to a switch under the dash. Just one wire that way.
martx-5
Be careful, some fans, such as my Spal, have permanent magnets and can run in only one direction.
TR3TR6
Art, I still have the positive ground on my car and all I did when installing my fan was connect the wires, check the direction of air flow and reversed the wires if it wasn't correct. Getting back to the shroud, one of the guys here made a shroud out of sheet metal using the cardboard one as a pattern and painted it the same color as his car. It really looked good and will probably last as long as the car.
Geo Hahn
I just came a across a photo I have of mine (apron off) when I still used the electric fan:
Might give some idea of how I mounted it -- I did the mounting with the apron still in place. I also knocked out the grid work at the bottom of the fan so I could still use the hand crank. Just had to insert the crank slowly (good idea anyway) so it would push the blade out of the way if it happened to be covering the hole.
TR3driver
Great Pumpkin - R.I.P
They are pretty much all permanent magnet motors; which means they will turn the other direction if you switch the leads. It's motors with wound fields that turn the same direction regardless of polarity (like the original heater and wiper motors on a TR3).
Check the instructions with the fan; some do say to reverse the blades for more efficient air flow, others do not.
CFM is a lot like horsepower; more is better so manufacturers find ways to give higher ratings that may bear little resemblance to reality. My 12" Hayden is only rated for 675 cfm through a "typical" radiator, but that seems to be enough for me. With my homebrew controller that measures the radiator outlet temp, the fan never runs for as much as a minute before shutting off again.
Eventually, I want to try building a variable speed controller, but haven't gotten there yet. I intend to also allow it to run for a few minutes after shutdown, to see if that helps reduce hard starting when hot.
R Air Intake Deflector - Radiator Austin Healey 8
K Radiator air deflector Austin Healey 6
I TR6 radiator air deflector recommendations Triumph 10
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
John Turney Radiator Air Flow Austin Healey 47
Monark192 Radiator lower air duct panel for 74.5 B MG 3
AUSMHLY radiator air shield wire placement Austin Healey 11
S Radiator Air Deflectors Austin Healey 3
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
S Install drain cock in radiator. MG 2
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
J BJ8 Radiator Fan Austin Healey 12
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
R TR6 Radiator protection shield differences Triumph 0
K For Sale TR3 Radiator Guard Triumph Classifieds 0
S For Sale Mg tf new radiator shell-slats-false nose-emblem MG Classifieds 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
edkap2002 TR6 lower radiator hose fitting Triumph 2
nevets Radiator Overflow Tank Austin Healey 23
K TR2/3/3A Radiator coolant level? Triumph 5
K TR2/3/3A Radiator drain tap? Triumph 4
D TR2/3/3A radiator overflow restrictor Triumph 9
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
G 100/6 Radiator cross member Austin Healey 6
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
S TR2/3/3A and the radiator was leaking. Triumph 7
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
B Radiator Baffle Installation Austin Healey 4
S Painting a BJ8 Radiator - any advice? Austin Healey 17
S Bugeye Radiator Tank Plug Size? Spridgets 24
FlyingCat Spitfire Electric Radiator Fan Triumph 10
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
FlyingCat Spitfire Radiator and fan Triumph 5
aero3113 Radiator overflow catch tank Austin Healey 15
