Radiator Shroud Question
bridgener
Well, we're trying to test-fit everything in place before getting the car into bodywork. We can't figure out how the radiator shrouds (air ducts?) fit. Can anyone tell me how they fit?
Thanks
Brian
bridgener
bridgener
The car is a 1962 BT7.
TimK
I don't have a picture, but they fit on each side of the the radiator with the narrow part at the top and the wider part on the bottom. They butt up against the edge of the shell where the fins start. If you could narrow your question it might help.
Check out this on Moss Motors web site:
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=28860
Johnny
Not an easy job fitting all to the shroud, but doable.
dvu101
My car is missing the shrouds. Who makes good ones?
TimK
Check out Moss Motors. You could probably make your own from sheet metal if you're not trying to be original.
BabaKahawa
Great question Brian.
I just picked one up from Moss and was wondering the same thing
bridgener
bridgener
Thanks for the responses!
Johnny, that picture you posted is just what I was looking for! I'm guessing that the lower mounting holes bolt to the grille mounting tabs that are riveted to the front cowl. Is this correct?
GregW
Platinum
Yes, but the bolt is actually a stud with a hex head in the middle of its length. Check out the drawing HERE and look at #75.
John_Progess
Check out the AH Club of Manitoba webb site,ahca.ca. Their newsletter of June 07 starting on page 6 has a great article on grille installation including the shroud. It was posted here some months back. Have a good day!
John
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
longbridgehealey Radiator shroud Jaguar 0
af3683 TR2/3/3A Radiator Air Deflector / Shroud Triumph 31
Patrick67BJ8 Kilmartin Radiator Fan Shroud Austin Healey 4
Brosky TR5/TR250 Sweet TR250 in NY, but where is radiator shroud?? Triumph 14
R Radiator shroud recommendations MG 18
P Radiator shroud Austin Healey 8
K radiator fan shroud Triumph 21
newmexTR3 TR2/3/3A 3A radiator shroud Triumph 5
T Radiator shroud Triumph 7
T Radiator Shroud Triumph 17
I TR6 radiator shroud for TR6 Triumph 3
P Radiator Fan Shroud [aka finger protector] Austin Healey 1
A TR5/TR250 TR-250 Radiator Shroud Triumph 5
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
J BJ8 Radiator Fan Austin Healey 12
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
R TR6 Radiator protection shield differences Triumph 0
K For Sale TR3 Radiator Guard Triumph Classifieds 0
S For Sale Mg tf new radiator shell-slats-false nose-emblem MG Classifieds 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
edkap2002 TR6 lower radiator hose fitting Triumph 2
nevets Radiator Overflow Tank Austin Healey 23
K TR2/3/3A Radiator coolant level? Triumph 5
K TR2/3/3A Radiator drain tap? Triumph 4
D TR2/3/3A radiator overflow restrictor Triumph 9
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
G 100/6 Radiator cross member Austin Healey 6
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
S TR2/3/3A and the radiator was leaking. Triumph 7
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
