1098 10CC crankshaft
Gerard
Looking for a 1098 10CC (2" main) crankshaft for an engine I'm hoping to build. I have one, but it's already been turned .030 and don't know if it'll even clean up at .040, even if I did want to use it. If anyone has some boat anchor around they want to quit tripping over, please let me know.
LarryK
Crank can be welded and remachined to specks by a good machine shop.
Gerard
Gerard
Yep, I know that, but doing that on 7 journals would be crazy expensive. I did that on the wedged Huffaker crank I have for another engine (one journal) but it doesn't make sense in this case. I recently missed one for $20 on ebay.:livid:
LarryK
But you would know exactly what you have and would not have to worry about the engine or take a chance on what you find. $200 isn't really that expensive considering the $ in the car anyway.
Gerard
Gerard
Maybe in Illinois, but not in California. I paid $300 for one journal, including nitriding, which this crank will need, and that was about 15 years ago.
G
Why wouldn't you want to use it if it cleaned up at .040"? Wasn't it just Kurt who had an extra?
At .040" all the factory hardening is gone.
Welding every journal on the crank would silly expensive. Gerard, I know someone who has several 10CC cranks, but he'll probably want more than $20 for it :smile: Call me if interested, and I'll put you two in touch
nomad
Don't think I care to tear down this engine for $20 either, Gerard.:glee:
Actually the engine has less than 40K and I would bet that a set of inserts and rings would put it on the road for many more miles.
Kurt.
Can it be re hardened?
Yes, Moldex and others get about $150 to nitrate a crank, and then there's shipping both ways. The .040 bearings might be the bigger chore, no one much stocks anything more than .030" these days, not to say they are not lying around some where, but their not going to fall out of tree and hit you on head :smile:, you're going to have to go hunting for them
G
I don't mind getting hit in the head w/ bearings, it's the cranks I worry about.:tennis:
Gerard 1098 10CC rear main seal conversion Spridgets 4
Gerard 1098 "10CC" rear main Spridgets 0
R Extra 948 and 1098 Engines Spridgets 9
JimLaney 1098 stuck lifters problems Spridgets 5
F Tightening the idler pulley bolt on a 1098 Spridgets 2
B 1098 motor Spridgets 2
F Swapping out original 1098 distributor to electronic Spridgets 13
C 1098 engine Spridgets 5
MY66AH 1098 Rebuild Spridgets 11
J Bad News 1098 Spridgets 14
Pythias 1098 worth saving? Spridgets 29
Gerard 1098 master cylinder springs Spridgets 0
A 1098 Oil Consumption Spridgets 11
T 1098 angry cc's of fury is enough to... Spridgets 4
britndablood FS 1098 with rib case in North Carolina Spridgets 0
scoutll Spin on Oil Filter conversion on a 1098 Spridgets 11
M 1098 engine core-need it ? Spridgets 10
M Differences in Slave Cylinders for 948/1098 & 1275 Spridgets 5
Michael Oritt 948 or 1098 Race Engine wanted Racing 3
jlaird Need a 1098 timeing chain cover. Spridgets 12
theleisure 1098 & 1275 Oil Pans-- Same or Different? Spridgets 4
M Found this in my 1098 Spridgets 14
M Do 1098 motors have fuel pumps ? Spridgets 8
M best 1098 motor to rebuild Spridgets 6
NardisCNC 1098 Distributor Cap Question.... Spridgets 7
D '66 1098 Midget,,,how hard to fix partial floor? Spridgets 7
Colin8 1098 Pistons Spridgets 0
Colin8 1098/1275 Crankshaft Pulley - Damper Spridgets 3
T 1098 valve clearance - .012 cold? Spridgets 1
T Spin-on conversion options for a 1098 Spridgets 2
jvandyke head gasket 1098 vs 1275 Spridgets 1
theleisure 1098 to 1275 swap list Spridgets 8
R Carb differences 1098 and 1275? Spridgets 6
N Clutch Wanted 1098 motor 1964 Sprite Mkll Spridgets 4
T Tips on pulling a Bugeye 1098 & smooth case trans Spridgets 7
T Checklist of changes to swap 1098 for 1275 Spridgets 9
Jim_Gruber Thermostat Housing for 1098 Spridgets 21
jvandyke 1098 vent tube Spridgets 77
Luke_Healey Weber DCOE 45 OK on a 1098 CC engine? Spridgets 2
Luke_Healey How to make my own 1098 radiator-to-waterpump hose Spridgets 19
Luke_Healey Professional troubleshooting for my 1098?? Spridgets 31
jvandyke 1098 exhaust options Spridgets 43
Luke_Healey Will this oil filter convertor work on my 1098? Spridgets 14
B 1275 exhaust on MKI Midget [1098] Spridgets 3
T 1275 donor for the Bugeye or stay with 1098? Spridgets 11
tony barnhill 1098 Cam Spridgets 17
Jayrz 1098 available Denver Spridgets 2
P proper ignition wires for 1098 CG...??? Austin Healey 2
racingenglishcars Block pocketing, 998 1098 Restoration & Tools 12
HAN8L1965 coil for 65 1098 Spridgets 13
