best 1098 motor to rebuild
mightymidget
I have just purchased another Midget, this time for parts, don't even know what year except it is an early one-No door handles-vehicle is two hours away and have purchased it over the phone with out seeing it in person. Typical mold covered neglected yard car.
Anyway the last Midget I purchased has a light knock in engine so needs to be rebuilt. If the motor is no good in the one I have just bought is there a preference on an early 1098 or later 1098 to build?
scoutll
The later 10 CC engine has bigger 2" crank journals, redesigned intake with a more positive attachment to the head, bigger intake valves and higher horsepower (59 instead of 56 for the 10cg).
If the parts car you bought has the original engine in it it will be a 10CG engine with the smaller 1.75" inch crank. The 10CC didn't come along until Feb 64 when the MKII Midget/MKIII Sprite debut.
The 10CC is probably the better engine, but there's not much wrong with the 10CG. I don't race by any means, but mine takes all I give it without any problems.
I would say the best 1098 to rebuild is the best one you have. :thumbsup:
tony barnhill
Great Pumpkin - R.I.P
There ya go, in a nutshell.
Spridget64SC
MM-
I agree with ScoutII, the best to rebuild is what you have. But to add something that might be helpful, the early and late 1098's do have different cylinder heads. The early 1098's had the 12G206 heads while the later have the 12G295 heads. The intake ports on the 295 heads are bigger as well as the intake valve itself. These heads will flow a good bit better in stock form than the 206. Exhaust port shapes and valve sizes are the same between the 206 and 295 heads. The 295 head also has the carb manifold locating ring. Not a problem using an earlier manifold, but does allow use of later manifolds too. The later 1098's also have less of a chance of having the dreaded aluminum rocker pedestals.
HTH,
Mike
jvandyke
How do you ID a head?
Spridget64SC
For all A-Series engines, 99% of the time the casting number will be cast into the head some where inside the valve cover area. The casting numbers for 948 heads seem to move around the most inside the valve cover area depending upon who cast the head. I have see a few times where the heads had very little of the number visible. Sometimes the factory actually stamped the part number (not casting number) on the head as well. This is mostly on the 1275 heads.
For 1098 heads, the casting number is usually between the #2 and #3 rocker pillar, counting from the front of the engine and under the rocker shaft. With a flashlight or other kind of helpful illlumination, you can see the casting number.
Vizard's books cover the common UK casting numbers pretty well. The US had some different heads for the 948 that aren't really discussed much. The 12G206 is much more common in the US as it was used on most of the 10CG engines. There are many more nuances of the various cylinder head castings, but mainly if you are planning for a full race port job and not stock or hot street use.
HTH
Mike
mctriumph TR2/3/3A the best kinda folks Triumph 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
tr6nitjulius For Sale "SOLD" Winter projects: Upgrades 4Sale or Reasonable Best Offer Triumph Classifieds 0
AngliaGT MGB-GT The Best Laid Plans....... MG 3
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
J Best Aluminum Fenders? Austin Healey 3
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
G Best fuel option for a 72 Midget Spridgets 5
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
JPSmit some days your best tool is a credit card Spridgets 2
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
D The best place to get shocks rebuilt. Spridgets 8
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
W Best source for Bugeye front shocks Spridgets 3
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Bob Claffie Best cruise in of the year Spotted 8
longbridgehealey Best way in Austin Healey 2
B TR4/4A What really is the best clutch/bearing combo Triumph 4
I Best glue for rubber door panels? Spridgets 3
N Best cam choice??? Spridgets 5
R TR2/3/3A Best day ever [so far] Triumph 1
C How best to restore red script on valve cover? Austin Healey 7
F Best $25 I've ever spent on my Healey - 2019 Austin Healey Concours Guidelines Austin Healey 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
D Best little tube bender Restoration & Tools 8
N Best lube for a Datsun gearbox?? Spridgets 6
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
I General TR Best car cover Triumph 8
M Best Interiors Austin Healey 20
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
N Best carpet glue???? Spridgets 5
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
B best diff British Motor Corp 5
Boink Pre-War MG-TB wins best in class at Forest Grove Concours MG 7
T TR2/3/3A What is best way to flush engine after antifreeze got in oil?? Triumph 2
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
MisterB Spitfire Best year for a Spitfire? Triumph 12
D TR4/4A Best SU overhaul service to use? Triumph 10
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
Gerald_Gordon TR4/4A Best carpet for TR4 Triumph 2
C Best Replacement BN1 Leaf Springs Austin Healey 5
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
A Best fibreglass/GRP Bugeye bonnet Spridgets 21
D TR2/3/3A Best TR3B seats - repair or replacement? Triumph 11
