Checklist of changes to swap 1098 for 1275
tdskip
Hi guys - hope everyone is doing well and having a good Holiday season.
I scored a healthy 1275 for my Bugeye, and while I should be focused on other projects I'm really eager to do the engine swap.
For planning purposes - what changes or replacements will I need to make to complete the swap from the existing 1098 (itself a swap from the original 998) and a new rib-case transmission?
Seems like new engine mounts etc would be in order since they are going to get touched anyway. Any other make sense things to address?
Thanks in advance for the help!
Tom
bugimike
Not too many changes, especially with a rib-case AND a 1275 (without the rib-case the switch might involve a new throw-out bearing and perhaps a different clutch fork, and maybe even a shortened/lengthened slave push-rod! New mounts, front and rear (trans) should be done since you have it all out anyway unless they look REALLY good!
drooartz
I assume the 1098 was running an electric fuel pump, otherwise you'll need to switch out the old mechanical pump as most 1275 blocks don't have the mounting for the mechanical pump.
Just watch the old "while I'm in there" -- or you'll be doing dic brakes, 3.90 rear end, carb rebuild... (I'm there right now).
Jim_Gruber
Backplates on a 1098 might be different from a 1275 but since you are replacing smoothcase with a rib case you should be in good shape. I'll assume you've already made a conversion to negative ground?
I'll be doing the same swap with Bugsy my '68 Sprite. It came with a "rebuilt" 1098 and a smoothcase. Got a 1275 and a ribcase in the back of the garage that needs a valve job. One of these days it will be "more power", "more power"!
bugimike
No, It is really not a necessary conversion, though I have made the switch!
Jim_Gruber
Use your generator off of the 1098 so you don't have to repolarize the generator. Also your BE needs a generator with a tach drive off of the back. So reuse what you are using now.
When I first got Bugsy he would start and run as long as you kept squirting gas down the carbs. Could not figure out why he wasn't getting any fuel. I cogitated and cogitated and after about a week, I realized when the DPO installed the 1098 in Bugsy he connected as positive ground instead of negative ground. I disconnected the battery, turned it around, and was rewarded by hearing the fuel pump kick right up and Bugsy fired up and has stayed running well ever since. Amazing enough, even though hooked up backwards, smoke did not come out of the wiring harness, starter worked fine. I repolarized the generator for negative ground and that was that.
tony barnhill
Great Pumpkin - R.I.P
Somewhere in this thread, you need to compile a complete checklist.
Billm
While Jim said that his fuelpump didn't work with positive ground I just want to say that it depends on which type of pump you have- the old original SU ones from the '60's didn't care what the polarity was but somewhere in the '70's they put diodes in the circuit so that they would only work one-way (maybe to sell more pumps?).
So if you have an old one (I won't run anything else) just clean the points and keep it running, it will work for a very long time.
Bill
Jim_Gruber
Yeah, Pump is not an old one. Something newer back there. Again surprised it didn't burn out after being hooked up positive ground.
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
MisterB Outer structure repair order/checklist Austin Healey 9
DerekJ Overdrive troubleshooting checklist Austin Healey 10
longbridgehealey startup checklist Spridgets 6
tmc Start up checklist Triumph 2
T TR4/4A Checklist for installing A-type O/D in TR4a Triumph 40
aeronca65t Race Weekend Checklist? Racing 9
Michael Oritt Pre-race checklist: An additional item Racing 7
beaulieu XK-120 checklist for barn find inspection ? Jaguar 26
G Making my winter maintenance checklist Triumph 11
N Checklist? 3000 Mark III Phase II Austin Healey 8
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
V Changes in TVR Parts Supply TVR 1
T TR6 TR6 Body Changes Triumph 1
B experience with tire size changes? Other British Cars 2
P TR6 TR6 Suspension changes Triumph 20
K STP oil additive between changes? Triumph 17
glemon TR5/TR250 TR250 Production Changes??? Triumph 4
Robert560 Weird "rough" idle problem after ignition changes. Austin Healey 18
Nelson SU float level changes Spridgets 8
1 Multiple fluid changes MG 18
aeronca65t SVRA-changes Racing 19
A TR6 TR6 Late model changes Triumph 1
bigjones New tires - alignment now changes? Triumph 2
vping Front Suspension. What design changes did it have? MG 5
VelodromeRacer Grill changes to Vintage race car? Racing 3
D Build Sheet Changes Triumph 15
R motor oil [changes] Austin Healey 10
kodanja Slight changes Triumph 16
P Generator to Alternator Swap Austin Healey 2
E TR6 looking for info on doing a T5 swap Triumph 5
DrEntropy MGB Generator to alternator swap MG 1
algot1901 Brake swap Other British Cars 13
BoyRacer Rover 3.5L (Buick 215 c.i.) Engine Swap Austin Healey 15
AUSMHLY Generator to Alternator Swap Austin Healey 20
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
P '58 XK150 Dynalite Alternator swap question Jaguar 5
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
W XJ6 Series I bumper swap to Series II Jaguar 0
Grantura_MKI T-Series So Cal MG swap meet. MG 4
T General TR Portland, OR British swap meet Triumph 2
A Bugeye engine swap, 948 to 1275 Austin Healey 11
doc50 Nash Metroplitan trans swap? Other British Cars 33
drooartz MGB Stuck in now, engine swap time MG 13
Grantura_MKI T-Series SoCal MG swap meet. MG 0
K TR2/3/3A Clutch for gearbox swap Triumph 14
Got_All_4 General TR TRF parts swap June 2 Triumph 3
Grantura_MKI T-Series MG So Cali swap meet. MG 3
M TR2/3/3A Tr3A transmission swap Triumph 7
