XK-120 checklist for barn find inspection ?
beaulieu
Hi
OK....well you have me excited to go look at the XK-120 , 30 years in a barn....well really a garage,
Anyway is there anywhere a checklist on what to look for ?
To me the most important thing is the body rust / corrosion ,
mechanical stuff will just need to be gone thru...
I will probably not get much help from the seller as far as history , So I will really have no information on why it was parked back then...
also are there any cheap 16 inch tires I can get at Walmart. Pepboys etc if I need to put something on it to get it rolling again ?
I am sorry for so many questions , but you guys know more than I can ever learn....
Thanks for your help
Beaulieu
PS....mostly I am trying to figure out what I am getting into , I know its old , its just things I would not think of when inspecting any old car,
Exotexs
tires will not be cheap in the size you need,
try https://cokertire.com
if the car is a California car, rust might not be such a problem - the California climate preserves cars.
I got my '65 S type in San Francisco where it was originally sold and where it remained all its life until I bought it and drove it 2,900 miles to Tennessee. (yes it brought me home in 4½ days, total exilaration and acceleration thru New Mexico's endless straights). it has zero rust. So you might find a diamond in the rough.
jessebogan
Look for cheap modern 16 tires for some of the small import SUVs. Not elegant, but they should do. Check all of the alloy panels for corrosion/damage. open the doors and check the sills underneath for rust.(In the cosmic scheme of things, even if its rusty, a parts car can bring well over 10K these days.) Look for the serial number plate under the hood, and try to see if any/all of the numbers match.Check the door hinge area. The hinges can be a real pain to repair. Check for having all of the bits, lights, grille, and so on. Also, look for things like 2inch sandcast carbs, bluemels steering wheel, borrani wires, all desireable options. Send photos!!
beaulieu
beaulieu
Thanks ,
any idea what the tire size is on those small SUVs ?
Beaulieu
beaulieu
beaulieu
Do these use Withworth wrenches ?
Beaulieu
jessebogan
I think they are 185/70 or 75 /16.I don't think anything wider will fit the wheels. I missed the fact that is a FHC. My personal favourite 120. Real art deco looking. Check that all the wood in the interior is present. Even if it is rough, you can use it for patterns.I would bet that the rear glass could be tricky to find. Otherwise, rust is still the biggest factor, but with a separate frame, even a rusty car can be useable. I hope you get it, they are a sharp looking part of history. And yes, there is some whitworth hardware used.
GregJ
If the car is original it will have nothing but British Standard and Whitworth hardware on it. If it has been in the USA for a while and been fettled by the local garage much you will find a lot of SAE hardware mixed in, Usually with poor threads left .
GregJ
beaulieu
beaulieu
Hi all...
thanks for your advise....
I looked at it today , its one of those unbelievable barnfind stories ,
So now I am broke because I bought it /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
But too tired after driving all day , will put together a story soon
Couple questions ,
how many 1954 XK120 FHC were built that year ?
did they originally have whitewalls ?
thanks
Beaulieu
Steve
Platinum
Congratulations! Pictures will be expected, as soon as you are able..... /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
This was the last year of production, and there were only 175 LHD coupes built that year. There were only 2,477 made during the entire production run. The very last coupe was built in July of 1954, production of all variants ending in August.
If it is RHD, then there were even fewer!
Dunlop whitewalls were an option for the 140 and 150, but not for the XK120. It's possible that it may have been fitted with them being a late production model, but there are no records of them being fitted at the factory.
beaulieu
beaulieu
Hi.....
any idea what first and last chassis numbers were in 1954 fot FHCs ?
its a powder blue car with red interior
and did it come with fenderskirts ? - there are none now /bcforum/images/%%GRAEMLIN_URL%%/frown.gif
Its super straight , no rust , no crashes
Beaulieu
get ready for too many XK120 questions,,,,,
Steve
Platinum
We can narrow the build date down to which month it was in!
Jan.......681309 to 681353
Feb.......681354 to 681398
Mar.......681399 to 681446
Apr.......681447 to 681465
May.......681466 to 681473
Jun.......681474 to 681482
Jul.......681483 to 681485
There are a few cars that were built earler (in October 1953) but in general that should narrow it down some. No LHD Coupes were built in August of 1954.
Steve
Platinum
Looking further, it appears that cars in Pastel Blue should have had a light blue interior......could it have been painted? Old English White, black, maroon or one of the shades of grey would have had a red interior.
beaulieu
beaulieu
Thanks Steve , I sent you a PM
It sure looks like light blue to me ,
unless they has a grey blue , heavy on the blue /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Beaulieu
beaulieu
beaulieu
Hi all
I am going down tomarrow and finish paying for the XK 120
While I was there I wanted to "oil it up"
well really just spray the wire wheel splines with PB blaster ,
the plug area has been soaking with Marvel oil for a week, so pull the plugs and fill the cylanders with more marvel,
Anything else to help it ?
I am going on vacation for 2 weeks so would like to let it
soak up and maybe free up the splines etc
Beaulieu
rotoflex
Remember PB Blaster is a penetrant, not a lubricant. After breaking the rust on the wheel splines, clean them off (hubs & wheels) & slop them with grease before driving.
Listen for deadly clunk-clunk when shifting into reverse or 1st, indicating splines are worn.
F For Sale Beautiful 1967 Triumph Bonneville T-120 Triumph Classifieds 1
B XK-120 tires Jaguar 7
R Modified XK 120 Jaguar 2
healeyblue XK 120 headlight mounting Jaguar 1
Brinkerhoff XK 120 project Jaguar 5
GBRandy Jaguar XK 120 Dash. Wood or wrapped? Jaguar 4
ttrotter Re-chrome within 120 mi. Piedmont Triad NC area? Restoration & Tools 5
equiprx XK 120 gone but not forgotten Jaguar 0
HealeyRick The Fast and the Furious XK 120 Jaguar 2
C How to Race Prep a Jaguar XK-120 Racing 0
aeronca65t XK-120-etc Spotted 10
T T-Series 120 miles without a hitch.... MG 7
T These must be worth more than $120 Lotus 1
F Xk 120 OTS door hinges Jaguar 3
PAUL161 Tony - - Jag 120 coupe ?? MG 7
beaulieu XK 120 Batteries - single 12v or pair of 6v ? Jaguar 7
beaulieu Whats in the trunk/ boot of a XK 120 when new ? Jaguar 1
poolboy Plaque in XK-120 Jaguar 13
S Disc Brakes XK 120 Jaguar 5
beaulieu XK 120 with Chevy V-8 ? Jaguar 12
wkilleffer Volvo Amazon/120 Other Cars 7
Lin Jaguar XK 120 Silver Paint? Jaguar 0
D XK 120 Quarterlight Hinges Jaguar 4
Bruce Bowker XK 120 Jaguar 0
J Windshield XK 120 FHC Jaguar 1
D 120 mirrors Jaguar 2
D xk 120 fhc Jaguar 3
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
MisterB Outer structure repair order/checklist Austin Healey 9
DerekJ Overdrive troubleshooting checklist Austin Healey 10
longbridgehealey startup checklist Spridgets 6
tmc Start up checklist Triumph 2
T TR4/4A Checklist for installing A-type O/D in TR4a Triumph 40
aeronca65t Race Weekend Checklist? Racing 9
Michael Oritt Pre-race checklist: An additional item Racing 7
T Checklist of changes to swap 1098 for 1275 Spridgets 9
G Making my winter maintenance checklist Triumph 11
N Checklist? 3000 Mark III Phase II Austin Healey 8
3798j Barn Find 200+ Cars Other Cars 3
Rut For Sale Barn of Triumphs Triumph Classifieds 10
Bob Claffie MGA Almost barn find MG 1
Basil Spitfire 74 Spitfire Barn Find Triumph 1
C My BJ8 Barn Find Austin Healey 15
S For Sale Big Barn Cleaning Triumph Classifieds 0
F 1960 FriskySport Barn Find Other British Cars 6
HealeyRick Rare Barn Find Valve Cover Racer Austin Healey 9
glemon TR6 Barn Find TR6 Triumph 9
R Questions about a barn find Austin Healey 18
T SE Massachusetts BN1 barn find Austin Healey 15
