1098 master cylinder springs
Gerard
I'm looking for 1098 master cylinder (bore) springs, These are slightly different than 948 master cylinder bore springs in that 948 springs are tapered at both ends, while 1098 springs taper at one end and straight at the other.
The differences are shown here. The middle spring is the 1098 version.
Moss is currently out of stock w/no ETA on availability.
If you have used ones or know of another source for new ones, please let me know.
Thanks!
Gerard
R Extra 948 and 1098 Engines Spridgets 9
JimLaney 1098 stuck lifters problems Spridgets 5
F Tightening the idler pulley bolt on a 1098 Spridgets 2
Gerard 1098 10CC rear main seal conversion Spridgets 4
B 1098 motor Spridgets 2
F Swapping out original 1098 distributor to electronic Spridgets 13
Gerard 1098 "10CC" rear main Spridgets 0
C 1098 engine Spridgets 5
MY66AH 1098 Rebuild Spridgets 11
Gerard 1098 10CC crankshaft Spridgets 14
J Bad News 1098 Spridgets 14
Pythias 1098 worth saving? Spridgets 29
A 1098 Oil Consumption Spridgets 11
T 1098 angry cc's of fury is enough to... Spridgets 4
britndablood FS 1098 with rib case in North Carolina Spridgets 0
scoutll Spin on Oil Filter conversion on a 1098 Spridgets 11
M 1098 engine core-need it ? Spridgets 10
M Differences in Slave Cylinders for 948/1098 & 1275 Spridgets 5
Michael Oritt 948 or 1098 Race Engine wanted Racing 3
jlaird Need a 1098 timeing chain cover. Spridgets 12
theleisure 1098 & 1275 Oil Pans-- Same or Different? Spridgets 4
M Found this in my 1098 Spridgets 14
M Do 1098 motors have fuel pumps ? Spridgets 8
M best 1098 motor to rebuild Spridgets 6
NardisCNC 1098 Distributor Cap Question.... Spridgets 7
D '66 1098 Midget,,,how hard to fix partial floor? Spridgets 7
Colin8 1098 Pistons Spridgets 0
Colin8 1098/1275 Crankshaft Pulley - Damper Spridgets 3
T 1098 valve clearance - .012 cold? Spridgets 1
T Spin-on conversion options for a 1098 Spridgets 2
jvandyke head gasket 1098 vs 1275 Spridgets 1
theleisure 1098 to 1275 swap list Spridgets 8
R Carb differences 1098 and 1275? Spridgets 6
N Clutch Wanted 1098 motor 1964 Sprite Mkll Spridgets 4
T Tips on pulling a Bugeye 1098 & smooth case trans Spridgets 7
T Checklist of changes to swap 1098 for 1275 Spridgets 9
Jim_Gruber Thermostat Housing for 1098 Spridgets 21
jvandyke 1098 vent tube Spridgets 77
Luke_Healey Weber DCOE 45 OK on a 1098 CC engine? Spridgets 2
Luke_Healey How to make my own 1098 radiator-to-waterpump hose Spridgets 19
Luke_Healey Professional troubleshooting for my 1098?? Spridgets 31
jvandyke 1098 exhaust options Spridgets 43
Luke_Healey Will this oil filter convertor work on my 1098? Spridgets 14
B 1275 exhaust on MKI Midget [1098] Spridgets 3
T 1275 donor for the Bugeye or stay with 1098? Spridgets 11
tony barnhill 1098 Cam Spridgets 17
Jayrz 1098 available Denver Spridgets 2
P proper ignition wires for 1098 CG...??? Austin Healey 2
racingenglishcars Block pocketing, 998 1098 Restoration & Tools 12
HAN8L1965 coil for 65 1098 Spridgets 13
