Spin on Oil Filter conversion on a 1098
scoutll
I also posted this on the MGE in case anyone sees it there too.
I finally got tired of the annual canister oil change, fighting to get a ring gasket to seat and then finding out it didn't when I get half a quart of oil squirting all over the frame and engine. I bought a spin on filter head unit from a 1275 to put on my 1098.
Before I do this:
Are there any tips for converting from you guys who have already done this? It looks pretty straight forward. Unhook the tube, remove the two block bolts, pull off the old canister unit. To install the spin on unit, reverse the procedure.... New gasket, some loctite on the block bolts....Anything else?
Does anyone have a list of correct spin on filters?
Thanks in advance folks.
As Roger Murtaugh says in Lethal Weapon ----- "I'm gettin' too old for this Sh**"......
Bryan
RickB
I did this on my Sprite, 948 motor.
It really was just as straightforward as it seems.
I have a spare filter in the trunk I'll get the number in a bit - I think it's a Valvoline brand.
BlueMax
If you want quality Mann GFE148, I can’t answer what Auto-Crap life time warranty will provide for that application. But GFE148 is the right fit for the spin on application.
RickB
The nice thing about spin on is they spin off easily, so you can replace them often.
I looked and mine is a Valvoline VO-25.
They had several at the True Value across the street so I bought them, insuring oil changes for a couple years.
Many will fit, but that should help with cross referencing.
Gerard
Installation is straight forward, just make sure you have the right length bolts and the right gasket.
There is a list of filters in my Tech section under the Info/Tuning drop down menu. It's probably not comprehensive as I complied this years ago, but there are quite a few of both types.
https://gerardsgarage.com/Garage/tech.htm
scoutll
scoutll
As far as I know a 1275 spin-on will fit right on a 948 or 1098.. RickB did it to his 948. I'm about to try
Pythias
I run a 1098 and this has been done to my engine. I can't imagine NOT doing it.
jlaird
Miss Agatha has a spin on complements of Hap. She is very pleased with the change.
scoutll
scoutll
tdskip said:
Agree Bill based on the other cars where I've done it. Any update Bryan?
I'm waiting for it to get here in the mail. I just changed the oil yesterday, so may wait until the next change to make the swap. I'll be sure to post on it though.
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
nevets Spin-On Oil Filter Adaptor Austin Healey 12
A TR6 spin on oil filter for tr6 Triumph 4
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
AUSMHLY Spin-oil filter, which filters? Austin Healey 25
R TR2/3/3A Spin-On Oil Filter 1954 TR-2 Triumph 8
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
TEM666666 Spin on oil filter conversion compatibility? Spridgets 9
H Spin-on oil filter for BJ8 Austin Healey 26
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
F Which spin-off oil filter adapter for my BT7? Advice please Austin Healey 7
Bugeyze Noisy spin on oil filter Austin Healey 9
NutmegCT TR2/3/3A spin on oil filter adapter? Triumph 2
B Spin on oil filter position Austin Healey 1
Trevor Jessie WTB a spin on oil filter head. Spridgets 2
D Stock oil filter vs spin on filter Austin Healey 17
D spin on oil filter conversion kit Spridgets 33
T S2 E-Type Oil Filter [original not spin-on] Jaguar 3
I 1275 spin on oil filter unit and pipe for sale? Spridgets 8
I spin on oil filter adapter recommendations? Spridgets 4
S Oil cooler and spin on filter adapter Triumph 10
mgedit TR2/3/3A TR3 Spin-on Oil Filter Triumph 7
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
T Question Regarding Old Spin On Oil Filter Design Austin Healey 1
bugedd Spin On oil filter adaptor wanted Spridgets 8
hymodyne GT6 spin-on oil filter adapter w/ oil cooler GT6 Triumph 12
Pythias Spin On Oil Filter: Survey Says? Spridgets 20
Mike_Roe Spin-on Oil FIlter O-rings? Triumph 1
doughairfield TR4/4A Spin on oil filter for TR4 Triumph 12
HEALEYJAG e-type spin on oil filter adapter Jaguar 5
jmwuva05 Low oil pressure after spin on filter Spridgets 13
martx-5 Spin On Oil Filter Adaptor Triumph 6
N Spin on oil filter adapters O-rings? Triumph 3
CinneaghTR Spin-on oil filter conversion for TRactor motor Triumph 7
T TR4/4A Oil filter of choice for the TR3/TR4 spin-on adaptor Triumph 18
G spin on oil filter--oil not being filtered Austin Healey 21
RedTR3 TR2/3/3A TR3 Spin-on oil filter adapter question Triumph 10
AUSMHLY Upright spin on oil filter Austin Healey 8
bcbennett Best oil filter for spin-on? Triumph 24
SCguy TR4/4A Tr4 Spin-on Oil filter Problem Triumph 2
bobh The New 2 Piece Spin on Oil FIlter Adapter Triumph 0
SherpaPilot Spin-On Oil Filter Triumph 3
A What spin-on oil filter do I use??? Triumph 6
jlaird Question, spin on oil filter Spridgets 8
mabbott TR6 TR-6 Spin-on oil filter p/n??? Triumph 4
drooartz Spin-on oil filter adaptor for 948 Spridgets 0
H Spin on Oil Filter Adaptor Austin Healey 3
Exotexs re: Spin-on oil filter adapters Jaguar 3
bobh Spin On Oil Filter Adapter Question Triumph 15
R Oil Filter BJ8 Spin on Austin Healey 16
