spin on oil filter--oil not being filtered
George_Haywood
I am changing the break in oil on my freshly rebuilt bj8 and when I removed the spin on oil filter there was no oil in it nor has there ever been any in it. There is oil being pumped to the upper part of the engine because the valve cover gasket has leaks and there is oil all over the valve stems and rockers. Also the fact that the valves have not seized after 200 miles makes me think that the oil pump is working. My oil pressure starts out at around 50 PSI when cold and drops to around 20-25 while driving and just below 20 at idle when hot. What could be some things that could cause this? The spin on adapter is a little over a year old and the filter is a UNIPART #GFE-22, if that helps with a diagnosis.
Keoke
Hi George, I would guess that you may have gotten a bad filter, although I have never heard of that. Sure glad the engine was oiling though. However, for a freshly built engine I would expect higher oil pressures at speed,50 psi, and ,30-to-40 at Idle. OTOH, it may have been restricted by something in that particular filter. I would replace it with a different vendors item and see if it fills. Others may have similar experiences and chime in.--Fwiw--Keoke
G
George_Haywood
Keoke, Thanks, I bought an AC/Delco filter today. Was looking for a Purolator but they didn't have any of the correct number in stock. Maybe in the next couple of days when I put it back together with the new filter things will improve. Isn't there a pressure relief spring that could effect the oil pressure and also bypass the filter if it is not set correctly?
George
shorn
Is it possible that the gasket that fits between the spin on adapter and the engine block has partially blocked the holes that lead to the filter?
Keoke
George
That's a good thought, yes there is a pressure relief valve in most spin on filters which if buggered could cause the problem.--Keoke
Bob McElwee
Make sure the spin on filter mounting is on correctly. Your symptons sound similar to a very bad experience I had with a rebuilt engine.
Once the mounting was correct, things were fine. Of course I also now have a crank that needs to be repaired.
G
George_Haywood
Thanks all, I'm getting a lot of replies saying that the adapter could be on incorrectly. I will check that out right now and let everyone know after I get it right.
George
G
George_Haywood
Keoke,
I put everything back together with a new oil filter and went for a drive. The car ran great and the oil pressure was higher. On start up it was 55-60 PSI, running @ about 40 MPH after warm up it was around 50 PSI. I think I'll put another couple of hundred miles on it and check the filter again just to make sure all is well with it. Thanks for your comments.
George
'65 bj8
Keoke
Hey George, that's great! next time you drive it and it is warmed up good just reach down and feel the filter if its hot I think that means it is filling up.--Keoke- /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
bob hughes
Its either that ot heat is being nicely conducted from the lump to the oil filter via the metal to metal connection.
Well done George, lets hope that all was caught in time and there are no after effects.
Bob
Keoke
---Well Yes Bob, there will be some thermal conductivity via the metal parts. However, the cross sectional area of those parts is relatively small and the contact between their faying surfaces is not necessarily uniform . Consequently, they will have a high thermal resistance to heat flow and the filter should be at a lower temperature than if it were filled with hot engine oil.---Keoke
Keoke
Hi Ed,
The AC # is PF-13. It has to work better than the Unipart filter which did nothing.
Hi George, if you have acess to a dealer that carries "WIX" oil filters their model 51085 is a good choice for your application. OH! ED you might try one too- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif --Keoke-AZ /bcforum/images/%%GRAEMLIN_URL%%/cowboy.gif
Ed_K
PF-13... I'll add that to my list. I had a PF-20 on my car when I got it. They are not usually stocked at most parts stores.
I already had that wix part number on my list.
Thanks to both !
Ed
Keoke
/bcforum/images/%%GRAEMLIN_URL%%/savewave.gif
Hey ED, I did a bit of checking when you mentioned you had a PF20 filter on your car. This suggests that you have a different adapter than George who uses the PF13 unit unless you changed it for a later adapter. Anyhoo, for the PF 20 filter replacement if required you will need a WIX # 51068.--Fwiw--Keoke
G
George_Haywood
Keoke, sorry for such a late return. I have been working on getting the last few things done on the Healey in preparation for the longest drive of its resurected life. Things like front and rear bumpers, apron and badge bar, interior panels, and those little angled brackets with the rubber bumpers that go just in front of the top frame attacing points at the top of the shut pillars. What are those things called and what do they do just kind of close up that vacant area there between the door seal and the top seal? Anyway we had a nice drive Sunday with my friends and put about 120 miles on the car without a single problem. It drove smoothly, had good oil pressure, and the temp. ran @ about 190 the whole time.
Thanks for the WIX oil filter number, I know that Wix has been recommended many times on the different forums concerning Healeys.
Take care,
George
Keoke
Keoke, sorry for such a late return. I have been working on getting the last few things done on the Healey in preparation for the longest drive of its resurected life. Things like front and rear bumpers, apron and badge bar, interior panels, and those little angled brackets with the rubber bumpers that go just in front of the top frame attacing points at the top of the shut pillars. What are those things called and what do they do just kind of close up that vacant area there between the door seal and the top seal?---------->
OH! they just be whachamacallits /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
But on the hood sticks that rest just above them are supposed to be two foam rubber pads, Together the pads and the rubber bumpers close up that vacant space.--- /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif---Keoke
Take care,
George
Good un on you--Keoke-AZ- /bcforum/images/%%GRAEMLIN_URL%%/cowboy.gif
Ed_K
I am not an expert on this subject but I was led to believe
that several different oil filters from each brand will screw on and work just the same as long as the base size and threads are the same and there are no clearance problems with the longer filters. For instance, even though an AC PF-20 works just fine ( it was very large compared to the napa gold and the K&N ), an AC PF-13 will probably also work if the base size and gasket location/geometry is the same. I remember reading someones post in this forum that said they use a different size K&N than most of us because of clearance problems. A PF-20 was a heavy duty application for trucks and thus had a larger filter area than an average filter for a car. It would be a better choice than a PF-13 if the PF-13 is smaller. It probably is if it is used mostly in cars. I like to know all of my options for parts in case of emergencies or in case one maker/vendor gets real proud of them buy raising his price !
Ed
vette
Hello George and Everyone, Why George, I had a similiar concern this spring when i prepped my Healey for the Summer season. When I changed the oil and filter, having removed the filter It appeared to be devoid of any residual oil. It Is a spin-on. Ran the car all the previous summer with no issues and good pressure. Engine still if fine today. But I was very worried. I let the filter drain upside down on the bench and got no oil out of it. I was really worried. Discussed it with friends, one clue to what was going on was that the oil that I removed from crankcase wasn't that dirty, I believed it had to have been getting filtered. I inspected the adapter in place. I was sure it was on right. I then took a 1 foot piece of 1/8th or 3/16th clear plastic tubing, the kind you would use in aquarium pumps, I slide the tubing into the holes in the adapter as far as they would go into the block, they went in many inches, I felt no resistance. I had to concluded that the passages were open with no restrictions. The only reason that I can conclude that the filter had no oil in it was that the filter is mounted horizontally, maybe even a slight downward angle towards the block. Having set all winter the oil just ran out of it. What I should have done was run the engine till warm, shut the engine off, and removed the filter immediately to see if it had any oil in it. but alas all summer again the engine is fine and the oil is not that dirty. I am sure the passages are open.
Dave C.
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
nevets Spin-On Oil Filter Adaptor Austin Healey 12
A TR6 spin on oil filter for tr6 Triumph 4
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
AUSMHLY Spin-oil filter, which filters? Austin Healey 25
R TR2/3/3A Spin-On Oil Filter 1954 TR-2 Triumph 8
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
TEM666666 Spin on oil filter conversion compatibility? Spridgets 9
H Spin-on oil filter for BJ8 Austin Healey 26
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
F Which spin-off oil filter adapter for my BT7? Advice please Austin Healey 7
Bugeyze Noisy spin on oil filter Austin Healey 9
NutmegCT TR2/3/3A spin on oil filter adapter? Triumph 2
B Spin on oil filter position Austin Healey 1
Trevor Jessie WTB a spin on oil filter head. Spridgets 2
D Stock oil filter vs spin on filter Austin Healey 17
D spin on oil filter conversion kit Spridgets 33
T S2 E-Type Oil Filter [original not spin-on] Jaguar 3
I 1275 spin on oil filter unit and pipe for sale? Spridgets 8
I spin on oil filter adapter recommendations? Spridgets 4
S Oil cooler and spin on filter adapter Triumph 10
scoutll Spin on Oil Filter conversion on a 1098 Spridgets 11
mgedit TR2/3/3A TR3 Spin-on Oil Filter Triumph 7
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
T Question Regarding Old Spin On Oil Filter Design Austin Healey 1
bugedd Spin On oil filter adaptor wanted Spridgets 8
hymodyne GT6 spin-on oil filter adapter w/ oil cooler GT6 Triumph 12
Pythias Spin On Oil Filter: Survey Says? Spridgets 20
Mike_Roe Spin-on Oil FIlter O-rings? Triumph 1
doughairfield TR4/4A Spin on oil filter for TR4 Triumph 12
HEALEYJAG e-type spin on oil filter adapter Jaguar 5
jmwuva05 Low oil pressure after spin on filter Spridgets 13
martx-5 Spin On Oil Filter Adaptor Triumph 6
N Spin on oil filter adapters O-rings? Triumph 3
CinneaghTR Spin-on oil filter conversion for TRactor motor Triumph 7
T TR4/4A Oil filter of choice for the TR3/TR4 spin-on adaptor Triumph 18
RedTR3 TR2/3/3A TR3 Spin-on oil filter adapter question Triumph 10
AUSMHLY Upright spin on oil filter Austin Healey 8
bcbennett Best oil filter for spin-on? Triumph 24
SCguy TR4/4A Tr4 Spin-on Oil filter Problem Triumph 2
bobh The New 2 Piece Spin on Oil FIlter Adapter Triumph 0
SherpaPilot Spin-On Oil Filter Triumph 3
A What spin-on oil filter do I use??? Triumph 6
jlaird Question, spin on oil filter Spridgets 8
mabbott TR6 TR-6 Spin-on oil filter p/n??? Triumph 4
drooartz Spin-on oil filter adaptor for 948 Spridgets 0
H Spin on Oil Filter Adaptor Austin Healey 3
Exotexs re: Spin-on oil filter adapters Jaguar 3
bobh Spin On Oil Filter Adapter Question Triumph 15
R Oil Filter BJ8 Spin on Austin Healey 16
