bobh
I've searched the forum to find the answer to a fairly simple question, but found nothing.
I changed the oil in the TR6 yesterday. At the same time I installed a spin on oil filter adapted that came with a used engine I bought years ago. I left the canister gasket in place when I installed the adapter. When I started the engine the adapter started leaking around the area where the adapter mates to the block.
My brother had the same problem on his TR250. He said the only way he was able to eliminate the leak was to remove the gasket.
I know that several of you have these adapters on your engines. Do you have the gasket? Or did you eliminate the gasket?
Thanks,
BOBH
Thanks,
BOBH
