Spin on oil filter adapters O-rings?
Norton47
While getting ready to re-assemble the engine, I was cleaning the spin on oil filter adapter. I noticed the main body to adapter square o ring was hardened and will need replacing.
My question is about the groove in the center of the adapter.
Is there supposed to be an o-ring there also? It looks like ti to me. Unfortunately, there isn't anything in the baggy that was holding it. I don't know if it dropped out and I missed it when I took it off, or if it was always missing or if there shouldn't be one.
The photo's in the BPNW online show a flat seal there and say MOCAL has improved the sealing. I can't find any other photo's.
Anyone got one on the bench or got one for Christmas and hasn't put it on yet?
Thanks
martx-5
I have the adaptor kit in front of me, but it's for a TR3. It definetly has a smaller O-Ring that sits inside a recess in the adaptor. It's a round section O-Ring, so it should be available at your local FLAPS. It measures about 1-5/8" OD and has a thickness of about 0.142". You're dimensions may be different, but you should be able to find something that fits your adaptor.
poolboy
Just recently put one on my 74 TR6 and agree with Art about the seal. The square O-ring is the same as the O-ring that was needed with the old cannister.
The other one surrounded the mounting bolt, though larger ID than the bolt's OD and fit in the machined flat surface of the conversion.
DNK
mark- are you talking about the big 5 inch one. Check the crevice where it seats. They usually get lost in there.
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
nevets Spin-On Oil Filter Adaptor Austin Healey 12
A TR6 spin on oil filter for tr6 Triumph 4
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
AUSMHLY Spin-oil filter, which filters? Austin Healey 25
R TR2/3/3A Spin-On Oil Filter 1954 TR-2 Triumph 8
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
TEM666666 Spin on oil filter conversion compatibility? Spridgets 9
H Spin-on oil filter for BJ8 Austin Healey 26
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
F Which spin-off oil filter adapter for my BT7? Advice please Austin Healey 7
Bugeyze Noisy spin on oil filter Austin Healey 9
NutmegCT TR2/3/3A spin on oil filter adapter? Triumph 2
B Spin on oil filter position Austin Healey 1
Trevor Jessie WTB a spin on oil filter head. Spridgets 2
D Stock oil filter vs spin on filter Austin Healey 17
D spin on oil filter conversion kit Spridgets 33
T S2 E-Type Oil Filter [original not spin-on] Jaguar 3
I 1275 spin on oil filter unit and pipe for sale? Spridgets 8
I spin on oil filter adapter recommendations? Spridgets 4
S Oil cooler and spin on filter adapter Triumph 10
scoutll Spin on Oil Filter conversion on a 1098 Spridgets 11
mgedit TR2/3/3A TR3 Spin-on Oil Filter Triumph 7
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
T Question Regarding Old Spin On Oil Filter Design Austin Healey 1
bugedd Spin On oil filter adaptor wanted Spridgets 8
hymodyne GT6 spin-on oil filter adapter w/ oil cooler GT6 Triumph 12
Pythias Spin On Oil Filter: Survey Says? Spridgets 20
Mike_Roe Spin-on Oil FIlter O-rings? Triumph 1
doughairfield TR4/4A Spin on oil filter for TR4 Triumph 12
HEALEYJAG e-type spin on oil filter adapter Jaguar 5
jmwuva05 Low oil pressure after spin on filter Spridgets 13
martx-5 Spin On Oil Filter Adaptor Triumph 6
CinneaghTR Spin-on oil filter conversion for TRactor motor Triumph 7
T TR4/4A Oil filter of choice for the TR3/TR4 spin-on adaptor Triumph 18
G spin on oil filter--oil not being filtered Austin Healey 21
RedTR3 TR2/3/3A TR3 Spin-on oil filter adapter question Triumph 10
AUSMHLY Upright spin on oil filter Austin Healey 8
bcbennett Best oil filter for spin-on? Triumph 24
SCguy TR4/4A Tr4 Spin-on Oil filter Problem Triumph 2
bobh The New 2 Piece Spin on Oil FIlter Adapter Triumph 0
SherpaPilot Spin-On Oil Filter Triumph 3
A What spin-on oil filter do I use??? Triumph 6
jlaird Question, spin on oil filter Spridgets 8
mabbott TR6 TR-6 Spin-on oil filter p/n??? Triumph 4
drooartz Spin-on oil filter adaptor for 948 Spridgets 0
H Spin on Oil Filter Adaptor Austin Healey 3
Exotexs re: Spin-on oil filter adapters Jaguar 3
bobh Spin On Oil Filter Adapter Question Triumph 15
R Oil Filter BJ8 Spin on Austin Healey 16
