Gear Ratios
Griz
I had heard this was the case, but now that I've nearly completed my BJ7 restoration and have been driving it for a few weeks, I see that there is really not much difference between 1st and 2nd gear. With all the engine torque available I find that starting in 2nd gear is no problem at all and I find myself doing so frequently. I'm curious, how many of you typically start out in 2nd? The only down-side I can see is maybe a little extra wear on the clutch disk.
Griz
Michael Oritt
Lugging an engine--as in applying a big load at too low rpm's in any gear--puts undue strain upon big end bearings, and I can't help but think that starting off the line in 2nd induces a similar load on the engine.
To me part of the joy of driving cars such as ours is working through the gears and if anything perhaps I am guilty of using the shifter more often than I have to, looking to stay in the power band.
I always start in 1st from a full stop; this is one--of several, IMO--benefits of a 3.54 rear-end: it makes both 1st and 2nd more usable. I will start in 2nd if I'm at least rolling a bit, since it has a synchro. I did start in 2nd from a stop at least occasionally before I put the taller rear-end in. When I recently replaced the clutch disk it had a broken spring, and I half suspect this behavior may have caused it.
Michael Oritt
I too have the 3.5 diff in my 100 (as well as a Smitty's five-speed conversion) which does make first a more useful and less noisy/jerky experience, but I still believe that first should be used from a stop no matter what box you have. Since first is non-synchro'd there is often a slight gear crunch when shifting into it from neutral and if this bothers you simply touch the very "edge" of second gear before pushing the stick into first (or even reverse)--the noise will be no more.
Griz
Griz
Too lazy right now to go get my service manual to look it up, but if 3.54 diff is the "taller" rear, what is the standard ratio (which I am positive I have)?
Griz
Jack T
Unless I'm on an uphill grade, I always start in 2nd. With the 3.91 rear end there's no lugging or slipping of the clutch involved.
dougie
Dido -
Install the 3.54:1 gears and really enjoy the big Healey 6-cylinder.
John Turney
I have the the 4.10 on my BN4 with OD. I always start in 2nd unless I'm pulling into the garage or caught in stop&go traffic. Even then it may not be low enough.
DerekJ
In terms of ratio there is in fact a big difference between 1st and 2nd gear. See the attached chart.
dancrim
Will the 3:54 gear set in my 65 BJ8 with OD make that much of a difference? $800
on sale at Moss now. Not exactly chump change. How would it pull when cruising
in OD, especially on a hill?
Will the 3:54 gear set in my 65 BJ8 with OD make that much of a difference? $800 on sale at Moss now.
Depends on how much and what kind of driving you do. I put a lot of miles on my BJ8--around 5K/year--and, while I prefer the backroads and twisties like most of us, I often have to drive many miles on highways and freeways to get to them. The 11% reduction in engine RPM wrought by the taller rearend significantly reduces vibration and engine noise around 70MPH, which you have to at least do to avoid being steamrolled by soccer moms in huge SUVs and douche-bros in their jacked-up city cruiser trucks. Although your 0-60 times will be increased a shade--and you'll need to get a ratio adapter or new gears in your speedometer--a well-tuned Big Healey engine has plenty of torque for the extra load.
A stock 3.91 diff with a taller OD--a 28% should be a drop-in--might be a good solution as well, and I've heard from at least one knowledgeable aficionado that a 3.54 rearend AND the taller OD makes the best highway cruiser of all. BTW, the 'original' 3.54 rearend was initially manufactured and sold by Mike Lempert--of custom steering wheel fame--for $200. There will also be shop setup fees, unless you're comfortable installing rearends.
Michael Oritt
Dancrim--
You're not going to save $800.00 as a result of lower fuel consumption but it sure will make a difference in the way your car feels at cruising speeds. Before installing the 3.5 I always felt I was "pushing against a wall" when travelling at 65-70+ mph. Now I am turning about 75 at a comfortable 3000 rpm's and because the Healey's power band is pretty broad I am usually able to make a pass without going down into 4th.
RDKeysor
Bronze
I bought my 3.5 pinion and ring gear from SC Parts in the UK for considerably less. I had it professionally installed in a differential provided by a fellow Healey club member. I think that cost was just over $250. Subsequently my fellow club members helped install the upgraded differential in my '60 BN7. It is absolutely silent. By the way, this car has a Smitty Toyota conversion. Likely it wasn't the best choice, not a Supra, etc., and likely from a truck as it was turning about 3000 RPM at 60 mph before the conversion. Changing the differential substantially reduced my RPMs in all gears, most noticeably in 5th.
steveg
I have the Supra 28% OD 5th with the original Lempert 3.54 diff. 3000 rpms is pushing 80mph. A friend has the 3.54 with 28% orig OD - same.
I also have the DWR 8, 278 degree cam. The Healey has plenty of torque to support this setup. Unequivocally recommended.
dancrim
Thanks guys. I guess I'll break down and go for it. Retired now and the car is getting a lot more use. Thanks again.
gonzo
I'm having a 3.54 ring and pinion installed in my AH 3000 BJ7 in the next few weeks. The mechanic doing the work will also check and replace bearings etc. if necessary. With essentially new differential components, what type gear oil is best? I read some about those running Redline gear oil (e.g. 75W x 90, GL-5) so is this suitable for diffs specifying GL-4? Thanks for the clarification. GONZO
Michael Oritt
Gonzo--
Differentials use a GL5 oil and transmissions with yellow metal such as ours use a GL4.
I use Amzoil Severe Gear 75-90 in the diff and Redline MT90 in the transmission.
Opinions will vary but do NOT use any GL5 product in your transmission as it will attack the synchros. Some diff oils claim a Gl4/5 rating but I am skeptical.
HealeyRick
Rut Transmission gear ratios Spridgets 18
losmorob Swapping rear axle gear ratios Spridgets 10
B TR4/4A gear ratios, tr4a irs O/D??? Triumph 2
Baz Gear ratios Spridgets 5
S Rear end gear ratios MG 2
L T-Series Gear box servicing cap. MG 5
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Todd78d Sprit MK1 gear box filler Spridgets 2
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
B Transmission Gear Lockouts Austin Healey 8
S Gear Shift Lever Travel Austin Healey 13
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
S For Sale Differentail gear sets available. Spridget, Morris Spridgets Classified 12
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
C Spitfire gear selection Triumph 10
JPSmit Gear reduction starters anyone? Restoration & Tools 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
DocDup1 TR4/4A Second Gear Bushing Triumph 6
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR2/3/3A Gear shift knob Triumph 8
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
AUSMHLY BJ8 Gear Shifting Austin Healey 5
R Bugeye reverse gear Spridgets 6
TomMull TR2/3/3A 1st gear again Triumph 3
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KVH General Tech Gear Shift Sticks Triumph 6
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Jim_Stevens TR2/3/3A Ring gear shot? Triumph 26
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
