TR2/3/3A Replacement Floor and Trunk Panel Quality
trmjr1
I acquired a 1956 TR3 this weekend. Need to replace floor and trunk panels. Anyone have experience with TRF or Moss Motors parts? Quality and fitment? Match the originals?
Thanks!
Tom
charleyf
I am working on a 1959 TR3. I have replaced the floors, sills and rockers. All from TRF. I used the upgraded sills and found them very good. The floors fit well and did have the captive nuts already welded on. The rocker panels did require some work to fit them. But that could have been due to the car I am working on.
No help on the trunk floor. Also some cheaper panels do not have the captive nuts welded on, so check on this.
Charley
T
trmjr1
Thanks for the replies! Much appreciated. I had a Spitfire years ago and TRF was my main source of parts so looks like they will be for the TR3 as well.
Tom
TomMull
Charley
From what I cab glean, TRF is the only one in the US carrying the correct inner sills, which I think they designed/commissioned. Earlier versions, which seemed to be the same from most suppliers, were plainly incorrect in several ways. I don't know if others have caught on yet.
Floors have been made by several sources and with the exception of the captive nuts, all relatively easy to fit.
I think the same is true for the trunk floors and rear panels, very little difference between suppliers. Most will need some reworking, particularly on older cars.
Tom
charleyf
Tom,
I agree on the newer TRF sills. I used one on a car 10 + years ago and it did not fit correctly. I recall that the floor was almost an inch off in height. So when TRF came out with their newer version that they produced I gave them a try on this latest car. I was very pleased with the results.
Charley
DavidApp
The sill problems may explain some of the issues I ran into on my car. Had blamed the PO but he may have done his best with what he had. There are 2 versions of trunk floor. One full width and the other is in 3 pieces, sides and center section as far as I remember.
David
martx-5
I used floor panels and the trunk (boot) floor panel from Moss. Both fit well and the floor panels came with the caged nuts welded in place. The trunk panel I used was one piece and looked as though there was no way to get it in there without cutting the panel. After about a half an hour of twisting an turning, it all of a sudden just sorta fell in. I must have had too much coffee that morning. Please note, the trunk floors are different between pre and post 60k cars. Also, the floor panel from Moss did not have the "L" bracket(s) for the rear, Hardura panel or the tabs for the wiring harness. My car is post 60k, and I bought these items about ten years ago, so YMMV.
CJD
Please note, the trunk floors are different between pre and post 60k cars. Also, the floor panel from Moss did not have .... the tabs for the wiring harness.
No matter how much I try to remember, even after 4 years, I find I still miss things like this. Thanks for the reminder, Art! Does anyone have a pic of the location of the wire loom tabs for an early car?
adcronin
John
I am quite sure I can help out with that information. Give me a day or two and I will provide narrative and photos.
Dan
badornato
after you finish the boot floor replacement be sure to install those little 3/8 plastic tubes that drain water from the exterior channel through the little 1/2 hole into the cavity of the rear fender.
the only place my TR was developing rust was in the trunk ... and always got water in the trunk when i wash the car.
finally figured out the problem was the lack of plastic tubes and water was draining in to the trunk (boot)
carpecursusII
I have purchased all the pieces, the best fit is as follows. Inner sills from TRF, floors from Moss or Rimmer, trunk floor (pre 60k) from TRF or VB. VB was actually stocking parts from TRF, at the time TRF was sold out with no restock date and VB had it in stock, it came with a TRF sticker still on it.
Hi Tom. I'm in Chicago too. Ever need a hand, get in touch! Always glad to help out a fellow LBC enthusiast.
And watch Cheftush's videos on YouTube. He's also a member here.
H trunk floor pan replacement 1964 BJ8 Austin Healey 2
apbos TR2/3/3A TR3a Trunk floor removal and replacement Triumph 20
T MGB-GT Anyone need a BGT replacement trunk floor? MG 0
B TR4/4A Floor pan replacement Triumph 4
Zitch TR4/4A Floor pan replacement Triumph 18
S TR2/3/3A Triumph TR3A Boot Floor Replacement - Looking for help Triumph 13
X Floor replacement Spridgets 1
bugedd Floor pan replacement Spridgets 12
B Floor Panel and Outrigger Replacement Austin Healey 8
K TR4/4A 4A Replacement floor panels? Triumph 0
apbos Bugeye floor replacement Spridgets 34
B TR2/3/3A TR3A floor replacement advice Triumph 11
T Anyone used Moss front floor pan replacement panel Spridgets 2
T Replacement floor panels Spridgets 9
T TR2/3/3A TR3 floor replacement. Engine in or out? Triumph 3
B Bugeye Floor Replacement Spridgets 2
71tr Replacement Floor Panels - Partials? Triumph 5
E TR2/3/3A TR2 Floor Panel Replacement Triumph 8
J TR6 tr6 rocker and floor replacement --?s and pictures Triumph 12
Stewart floor pan replacement MG 34
jjbunn Floor Pan Replacement Cost Triumph 10
NutmegCT TR2/3/3A Floor replacement TR3A Triumph 11
C TR6 how to go about floor sill replacement? TR6 Triumph 10
J TR6 tr6 floor board replacement Triumph 14
HAN8L1965 Replacement Floor Pan Spridgets 1
PeterK TR4/4A TR4A floor replacement Triumph 10
C Floor and rocker replacement ? Triumph 8
frankenstang57 Spitfire spitfire floor replacement? Triumph 1
bcbennett Floor pan replacement Triumph 4
svtmikey GT6 Floor Pan replacement [GT6] any helpful hints Triumph 1
J BJ8 rear boot floor replacement. Austin Healey 9
C Floor Pan Replacement by Novice MG 2
aeronca65t Sill and Floor pan replacement MG 3
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
WHT Rocker Arm Shaft Replacement Austin Healey 21
Celtic 77 MGB Seat webbing replacement. MG 1
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Celtic 77 MGB Seat Diaphragm replacement MG 0
Celtic 77 MGB 1977 seat webbing replacement. MG 1
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
K TR2/3/3A Wing mirror replacement again... Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
B T-Series Battery replacement mgtd MG 2
F TR4/4A Speedometer cable replacement access Triumph 0
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
