XK 140 front transmission seal
Mac
The manual says very little on how to take the front transmission seal off and replace. Mine has a metal cover plate over the seal. I'm wondering if that pops out or you need to take the whole front cover off to take the seal out? Mac
LarryK
Take front cover off and press seal out. Be careful, lots of aluminum, with seal being steel. Press new on one carefully. If you need seal take to a regular parts store, not AutoZone etc., they can cross #s.
T XK120 fit 140 rack & pinion Jaguar 3
JPSmit Jag 140 Roadster Spotted 3
K Jaguar 140 Restoration Link? Jaguar 2
Thomas591 XK 140 FHC Frame dimensions Jaguar 9
M XK 140 tires Jaguar 3
PAUL161 Question for Hap and Others. 140 hp XPEG? MG 1
dougie UBJ 140 For Sale on Ebay Austin Healey 0
M XK 140 Fuel Gauge Jaguar 3
M XK 140 boot handle Jaguar 1
M XK 140 color codes Jaguar 0
M XK 140 fender skirts [spats] Jaguar 0
M XK 140 color combination Jaguar 6
M XK 140 cannister air cleaner Jaguar 1
M XK 140 Sump color Jaguar 4
M XK 140 engine color Jaguar 2
M XK 140 windshield Jaguar 2
M XK 140 doors Jaguar 3
M XK 140 inner rails Jaguar 0
M XK 140 gas tank Jaguar 4
M XK 140 Lower Ball Joint Jaguar 1
M XK 140 Clutch Pedal Shaft Jaguar 1
M XK 140 door seal Jaguar 2
M XK 140 battery Jaguar 4
M XK 140/150 Jaguars Jaguar 13
Bruce Bowker 140 mph speedometer Austin Healey 20
J XK 140 roadster- fire sale Jaguar 2
Basil First 140 in the Gallery! Jaguar 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
