XK 140 Lower Ball Joint
Mac
I noticed that there is a little up and down movement in the lower ball joint, not much but maybe a 32nd of an inch. Would this be normal or should there be zero movement? If no movement, is there a way to tighten them up? Mac
piman
Hello Mac,
you should not have any discernable movement and the joint should be replaced. I'm not familiar with the 140 but if it is the same joint as my MK 2 then, although there are shims in the joint they are for initial installation and not wear adjustment.
Alec
T XK120 fit 140 rack & pinion Jaguar 3
JPSmit Jag 140 Roadster Spotted 3
K Jaguar 140 Restoration Link? Jaguar 2
Thomas591 XK 140 FHC Frame dimensions Jaguar 9
M XK 140 tires Jaguar 3
PAUL161 Question for Hap and Others. 140 hp XPEG? MG 1
dougie UBJ 140 For Sale on Ebay Austin Healey 0
M XK 140 Fuel Gauge Jaguar 3
M XK 140 boot handle Jaguar 1
M XK 140 front transmission seal Jaguar 1
M XK 140 color codes Jaguar 0
M XK 140 fender skirts [spats] Jaguar 0
M XK 140 color combination Jaguar 6
M XK 140 cannister air cleaner Jaguar 1
M XK 140 Sump color Jaguar 4
M XK 140 engine color Jaguar 2
M XK 140 windshield Jaguar 2
M XK 140 doors Jaguar 3
M XK 140 inner rails Jaguar 0
M XK 140 gas tank Jaguar 4
M XK 140 Clutch Pedal Shaft Jaguar 1
M XK 140 door seal Jaguar 2
M XK 140 battery Jaguar 4
M XK 140/150 Jaguars Jaguar 13
Bruce Bowker 140 mph speedometer Austin Healey 20
J XK 140 roadster- fire sale Jaguar 2
Basil First 140 in the Gallery! Jaguar 3
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
S TR2/3/3A lower small brass bushing Triumph 13
S TR2/3/3A steel bushings for the lower Arms Triumph 10
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
R TR6 Lower A-arm trunnion bushings Triumph 18
edkap2002 TR6 lower radiator hose fitting Triumph 2
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
B TR2/3/3A lower wishbone installation Triumph 5
L TR2/3/3A Bent lower wishbone arms Triumph 6
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
KVH General TR Pressing in the Lower Control Arm Bushing Triumph 6
C TR6 Lower A-arms Triumph 8
wangdango BJ8 lower radiator hose! Austin Healey 2
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
Rut TR4/4A Lower fulcrum brackets Triumph 3
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
Tr3aguy TR2/3/3A Lower control arm question Triumph 2
