Hi
We have a very nice day in the Northwest. Went to fetch a part for the truck top down, wind and sun.
The throttle wanted to stick causing the rpm at idle to set about 1000 rpm high, blip the foot feed and it would usually come down. Pulled over on the way home to investigate and while under the hood, I hear a POP and a p_ss_ng sound.
Found the top hose spraying water from a couple of pin holes.
I managed to get the pressure off and wrap the hose with black tape from the trunk kit and got home. I thought I had a set of used hoses that came from the previous owner, but must have done the right thing and tossed them.
SO, the real question. What is the difference between the green hose (which is currently installed and leaking) and the black hoses. I assume green was original (costs more)
Are they worth the money difference? Any insights on best deals?
Thanks
Thanks
