Tuftrided Rocker Shaft
glemon
Do you need one? they are about 3x more expensive, I have a mild cam in my TR250, not exactly the same specs but in the ballpark of the TR5 (fuel injection) cam.
Brosky
I bought a new shaft with reconditioned rockers from TRF when I rebuilt my engine. I don't think that it was Tuftrided, just hardened and it's been just fine with my TH5 cam.
DougF
I put one in my TR6 engine, but it hasn't seen enough run time to determine it's added cost wear factor. Maybe in another 5-10 years. The previous shaft showed minor wear after 30-40,000 miles. It's still on my back up engine.
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
WHT Rocker Arm Shaft Replacement Austin Healey 21
G Installing New Rocker Shaft Assembly Austin Healey 3
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
Hamish Racing General TR Rocker cover identification please. Triumph 2
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
H Rocker Cover Data Plate Austin Healey 15
Twit TR4/4A 1.5 in outside diameter rocker cover pipe Triumph 3
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
S TR2/3/3A All new valve train - no adjustment at rocker arms Triumph 12
M Rocker feed kit for 1500 from Victoria British Spridgets 0
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
Jim_Stevens For Sale New Rocker panels TR3A Triumph Classifieds 1
P TR6 Rocker panel hole Triumph 16
D MGB MGB rocker shaft shims MG 1
Lukens Outer rocker showing "rust" Restoration & Tools 11
Joe_Healey 100 Chrome Rocker cover and air cleaner option Austin Healey 0
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
D rocker arm assembly Austin Healey 14
Rut Replacing rocker assembly Spridgets 1
JimLaney Rocker shaft plug/screw delima Spridgets 3
J TR4/4A New Rocker panels [sills] not round enough Triumph 10
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
P Rocker Cover Vent Spridgets 22
matmire rocker arm stress cracks? advice please. Spridgets 2
red57 Outer Sill/Rocker fit problem Austin Healey 11
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
M TR6 rocker shaft install tr6 Triumph 2
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
KVH TR4/4A Rocker Shaft Lubrication, and Issue with Push Rods Triumph 1
S TR2/3/3A rocker covers again Triumph 13
M TR2/3/3A Rocker cover question Triumph 11
S MGB-GT Wanted: REMCO MG Rocker/Valve Cover MG 0
S TR2/3/3A rocker cover panels for the pre60K tr3 Triumph 1
S A few valve cover [rocker cover] related questions, 3000, BJ8. Austin Healey 9
T TR2/3/3A TR Rocker Arm Spacers Triumph 7
Rut Which rocker assembly? Spridgets 7
B TR2/3/3A Questions about that rocker cover I "won" on E bay Triumph 6
T TR2/3/3A Requesting some picture of the outer Rocker panel Triumph 19
Scot1966 TR6 TR6 rocker panel fit Triumph 6
S TR2/3/3A Bolting the rocker shaft Triumph 3
J TR2/3/3A Installing new rocker arm shaft. Triumph 6
J Healey 100 -- Broken rocker and bent push rods !!! Austin Healey 7
A TR2/3/3A 1959 TR3 Inner and Outer Rocker Replacement Bracing Triumph 10
J Rocker valve assembly picture Austin Healey 6
