Trafficator/Steering Wheel
G
I am trying to tighten a wooden steering wheel on my 59 BT7. The little screws around the wheel (behind the trafficator) are tight but the wheel is loose.
Before I break the trafficator, I think I had better ask for help in getting the trafficator off/steering wheel tightened.
Thanks,
Will HArrison
1959 BT7
bighly
I guess it depends upon what you mean by loose.
If you have a telescopic (adjustable) steering column then tighten the stop ring. But thats probably too easy.
If yours is non-adjustable you'll need to get to the column nut and tighten that.
If you have play then your opening another bag of worms such as idler, idler arm, bushings etc.
Dave Russell
Yoda - R.I.P
Will,
Do you have a "Factory Service Manual" for your car? It has detailed instructions for steering wheel removal & much more. If not, you really need to get one. They are readily available from many vendors. I got mine from
https://www.britishcarspecialists.com/
[ 10-23-2002: Message edited by: Dave Russell ]</p>
slider
Will,
I have a BJ8 and took my trafficator apart this summer to replace the turn signal wiring harness. To get the trafficator out of the hub, you'll need to back out the three small set screws that you'll find on the back side of the steering wheel hub. The screws are in the 12:00, 4:00 and 8:00 positions. Once you've taken those screws out, the whole trafficator can be gently pulled out of the hub toward you. Because I have an adjustable steering wheel, my hub may be different than yours, but I don't have a retaining nut per se that tightens the wheel onto the stator tube. The end of the stator tube is splined and the steering wheel slides onto it, just like a splined wheel fits onto a hub. A small circular spring retaining clip snaps onto the end of the stator tube and prevents the steering wheel from being pulled all the way off and ending up in your lap. My guess is you most likely don't have play where the wheel meets the stator tube, the play is more likely elsewhere in the linkage.
F.Y.I. The trafficator is a little bit like a Rubic's Cube, but it stays in the wheel hub if using the above process. You don't have to take it apart to get to the stator tube/steering wheel point.
Best of luck
David Z.
G
Is there anything to taking off the trafficator
other than taking out the screws around the outside edge of the wheel. Does the trafficator screw off? I feel like I could easily break it
Will Harrison
G
Will Harrison
A Austin A40 trafficator steering wheel Other British Cars 5
M Trafficator and steering adjustment Austin Healey 4
bt7tricarb Trafficator question [adjustable steering] Austin Healey 22
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
F Wanted TR3A control head parts (trafficator) Triumph Classifieds 4
F TR2/3/3A Trafficator base Triumph 6
Rob Dodge Trafficator arm issues. Jaguar 2
Lin Another Trafficator/Control Head Question Austin Healey 10
Michael Oritt Trafficator reinstallation Austin Healey 2
Michael Oritt Trafficator repair and refinish recommendations Austin Healey 6
jfarris TR2/3/3A Access to trafficator Triumph 5
Johnny AH BJ7 Trafficator Color? Austin Healey 7
Lin Another trafficator issue Austin Healey 8
Michael Oritt Trafficator stopped self-cancelling Austin Healey 19
R Turn signal switch [trafficator] Austin Healey 1
6TTR3A Trade TR3 TRafficator parts Triumph Classifieds 0
M Questions about stator tube and trafficator fixation Austin Healey 31
Griz Trafficator Wiring Question Austin Healey 16
B TR2/3/3A Most likely Trafficator Problem Triumph 5
R TR2/3/3A Turn signal switch [trafficator] Triumph 2
maxwedge5281 refinish trafficator plastic? Austin Healey 20
trotti Control head / trafficator questions Austin Healey 14
J TR2/3/3A Correct trafficator control head? Triumph 4
R trafficator/control head rebuild Austin Healey 10
richberman trafficator part? Austin Healey 2
B Trafficator rebuild Austin Healey 2
M Healey 100-4 Trafficator Lever Needed Austin Healey 5
F TR2/3/3A Horn Button TR3 Trafficator; Bad ground? Triumph 4
Brosky New "Trafficator" now available from Classic Tech Triumph 16
rjc157 trafficator Austin Healey 4
RAC68 Trafficator Head Tube Problem Austin Healey 12
BobbyD TRafficator Signal LED Buzzer Thing Triumph 7
rjc157 trafficator Austin Healey 3
AUSMHLY Trafficator - how to check if it's set correctly Austin Healey 15
martx-5 TR2/3/3A New "Trafficator" for my TR3 Triumph 5
N Healey 100-4 Trafficator Austin Healey 9
Marvin Gruber A/H trafficator part Austin Healey 0
E trafficator Triumph 14
C Trafficator parts Austin Healey 4
H Non adjustable trafficator Austin Healey 2
H Rebuilding a trafficator Austin Healey 4
AUSMHLY trafficator return Austin Healey 21
Johnny Horn switch/trafficator, what again? Austin Healey 5
J Trafficator tests Austin Healey 3
timbn2 "Control Head Assembly" = Trafficator ? Austin Healey 10
SHG Trafficator is Killing Me! Austin Healey 35
Lin Trafficator Rebuild Latest Austin Healey 0
N BN1 Trafficator Austin Healey 4
Lin Control head "Trafficator" Rebuild Austin Healey 9
Lin Trafficator, control head, turn signal switch/horn Austin Healey 5
