Horn switch/trafficator, what again?
Johnny
Can't seem to locate who or where the great pictures and instructions on how to disassemble the Healey turn signal switch. I found Steve Byers article on the Jim Lerner's website but there were no photo's.
Can anyone help?
/ubbthreads/images/graemlins/nopity.gif
Ray Smith
Johnny,
I had a similar problem when rebuilding my trafficator. One of the members, I believe his name was Lynn, sent pics and a write-up that was of tremendous help. Perhaps if he reads this post he will reply.
Lin Trafficator, control head, turn signal switch/horn Austin Healey 5
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
S Indicator / Horn Switch Austin Healey 10
TRMark T-Series Horn/Dipper Switch MG 4
K Is my BJ8 horn switch connected to ground positively or negatively? Austin Healey 3
Scotsman TR2/3/3A Signal switch on TR3 Horn Control Head not canceling Triumph 20
I TR2/3/3A Horn, Turn Signal Switch Triumph 2
jjbunn E-Type Turn Switch - loose braid for horn? Jaguar 6
Got_All_4 Weird R&R the turn signal switch and horn blows Triumph 8
KVH Horn Relay Switch Triumph 1
P Heater switch and horn problems Triumph 5
2 LT/Switch makes horn blow Triumph 16
P TR2/3/3A TR2 Horn Mounts Triumph 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB HELP, my horn does not work! MG 8
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A The horn and turn signal assembly. Triumph 3
D TR2/3/3A Traffic at or and horn button not working Triumph 2
P TR2/3/3A 6 volt Oogah horn Triumph 8
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
jehuie Morris Minor horn mystery British Motor Corp 12
Sixpack TR6 Horn Mystery Triumph 3
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
R Horn relay Spridgets 2
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
P TR6 TR6 Horn Relay Problems Triumph 8
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
nichola TR6 What is this, connected to horn relay? Triumph 8
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
71TR6 TR2/3/3A Windtone WT618 horn current Triumph 9
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
D TR6 Replacing Horn insert in steering column Triumph 11
nevets BN6 horn button Austin Healey 17
C TR2/3/3A Horn Control replacement Triumph 3
Bayless Question on '67 horn button Spridgets 5
K TR2/3/3A Horn Button Removal Triumph 10
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
R German horn on BJ7 Austin Healey 8
longbridgehealey Horn question follow up Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
K Restoring Horn Push Button Austin Healey 12
Jim_Gruber Intermittent Horn Spridgets 2
Joe_Healey TR5/TR250 Bubba Horn Triumph 0
G TR4/4A Horn Brush Question Triumph 7
edkap2002 TR6 horn brush Triumph 3
