Well it seems that the more I delve into my TR the more I find that it could use some attention. Basically I started to just remove the windscreen, add a new glass seal, cowl seal, repaint the windscreen frame and cowl. Install all new crashpads and recover the dash support. I already had a new wood dashboard. I have removed everything including the steering column and metal dash, heater box and hoses. So now I'm staring at pretty much a bare dash with hanging wiring and some cables hanging from the firewall. I started cleaning the firewall with solvent to remove years of grime and I noticed that the seam sealer is like a black tar which the original paint does not stick to very well. Also, in some areas along the floor pan along the sills the seam sealer easily separates from the reddish primer. So now I'm thinking maybe I should remove all of the old seam sealer and reseal all the seams at least along the seams above the heater box since the area on the other side would collect water and possibly leak into the interior. I read about the drain tubes which are pretty much useless as they dump water behind the fender with nowhere to drain. A re-route of the drain tube is in order since I read about someone doing this. OK, enough rambling. What should I use to re-seal the panel joints? I noticed there's some spots of surface rust on the floor pan so I was going to sand those areas down and may use some POR-15 on the floor pan. So then I thought maybe I should just paint the floorpan black and for that matter the entire interior except under the dash which I might just paint white so when working under it the light would reflect just nicely. Anyway any comments are appreciated. I'm no stranger to working on cars and painting them and doing some restorations. I just wanted to hear what you guys have to say about it. Thanks.
Art (the new old guy on the forum)
