TR2/3/3A TR3 Instrument Glass
Tinkerman
I know that there are flat and domed instrument glass. My question, though is, are they interchangeable? That is to say if I buy an instrument with flat glass, can I put a domed one in its place?
Thanks, Tinkerman
MGTF1250Dave
I'm quite confidant that it can be done. A few years age I converted a TR4 electric Temperature gauge to a TR3 appearing gauge by switching to the convex lens. As I recall I had a problem with a replacement convex lens I had ordered from one of the big suppliers, I think it was slightly too big. I ended up using the lens from an original TR3 gauge and it fit fine.
Adrio
I have switched them with no problem. In fact I just put a curved glass on an early TR4 temp guage that had had a flat glass from the factory.
TR3driver
Great Pumpkin - R.I.P
The assembled instruments are interchangeable, too.
The dash cutout is a very standard size, so even modern gauges fit fine (although they don't have windows for the dash lights).
Tinkerman
Tinkerman
Thanks all of you. I kind of thought that would be the case.
Regards to all, Tinkerman
angelfj1
This is a great DIY project. The $$$ savings are a big motivation, but the parts,if needed are available and EXPENSIVE. I was recently quoted the following by a major instrument repair firm:
Instrument R&R
Tach & Speedo $160 each
Fuel Level , Amps & Oil Press $105
Water Temp $120
This did not include replacement glass or bezels.
Replacement glass/bezels for the Tach & Speedo are $39.95 each and the 52mm units are $12.95 each; bezel gasket kit a $16.95 (for the 6 gauge set.
Ouch!!!
ekamm TR2/3/3A removing tr3 instrument panel Triumph 15
Tinkerman TR2/3/3A Instrument Panel TR3, Question about back. Triumph 29
prb51 TR2/3/3A TR3 instrument lights Triumph 4
mrv8q TR2/3/3A TR3 Instrument Panel Bezel Removal Triumph 4
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
R TR2/3/3A TR3 Wiper motor Triumph 10
