Start up Sanity check…..
mjobrien
I’m getting ready (next few weeks) to start my BN1 after 18 years and a ground up rebuild. On the wiring side I had thought it best to blank off all the wires not used for starting (Fuel gauge, lights, horns, signals, O/D, wiper, heater). I did connect the tachometer, oil/water, all ignition circuits, fuel pump, battery switch, chassis grounds, generator, relay, voltage regulator.
I was wondering is this good route to go when you just have a chassis?
Any pointes would be appreciated, on this as well as any other start up pointers.....
Michael.
HEALEYJAG
Michael :
Sounds good to me ..on my BJ8 rebuild in the mid 80's I made sure there was no spark to the plugs as I first turned her over to make sure the oil presure was good going to the gauge.
Once I established pressure to the gauge I reconnected the electrics and she roared to life..Hopefully you have the same results..Can't wait for the BIG DAY!!!
Pete
krag50
Hi all. After a rebuild on my carbs , I'm wondering if anyone has a good starting point on setting the three adjustment screws to get the car running, before the final tuning. HD-8's Thanks
Dave Russell
Yoda - R.I.P
Q TR2/3/3A Where to start?! Triumph 13
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 9
dougie Bruce McLaren's start in an Austin Healey Austin Healey 0
K TR2/3/3A Hard start questions.... Triumph 4
pairof75's General TR Circulate fluids without engine start Triumph 10
S TR2/3/3A Will Not Start Triumph 52
R TR2/3/3A Re-start after total restoration Triumph 22
S General MG 77 MG no start MG 31
B Cold Start Problems BN7 Austin Healey 21
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T 100-6 start up issues Austin Healey 6
tr6nitjulius General TR AutoX & Rallye Start TRIUMPHest 2019 Triumph 0
K TR2/3/3A Mystery stall and no start? Triumph 7
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
tr6nitjulius New Official Start Great Race 6/22/19 Video Other Cars 0
tr6nitjulius Great Race 2019 Official Start 6/22/19 pics Other Cars 2
I General TR TR6 won’t start, no lights Triumph 12
RAC68 Healey Will Not Start Austin Healey 5
S TR2/3/3A try start it with the key and it blows the fuse Triumph 7
J TR6 Wont Start Triumph 10
Sarastro TR4/4A Another milestone: first engine start Triumph 8
HighAltitudeTR3 TR2/3/3A Doesn’t want to start up again after a ride... Triumph 24
Gerry M TR6 TR6 Won't Start Just Clicks Triumph 17
G Failure on Initial Engine Start After Rebuild Austin Healey 176
M Cold start problems Austin Healey 33
Drone Dog Lily Engine first start Austin Healey 9
KVH General TR TR4A Engine Won't Start Triumph 34
gbtr6 TR6 TR6 no start after running amazingly well til now. Triumph 16
K TR4/4A Success on the TR 4A No Start.... Triumph 0
K TR4/4A 4A No Start? Triumph 14
C TR6 Zenith Strombers won't start when warm. Triumph 2
C Strange...can won't start and then magically ressurects Austin Healey 16
E TR4/4A TR4 Start up after 35 Years Triumph 1
C Static timing before engine start up Spridgets 4
KVH General Tech Start Up after Rebuild Triumph 5
P TR6 Car won't start after backing out of garage Triumph 21
Tinkerman TR2/3/3A 60 TR3A wont start??????????????? Triumph 7
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
M BT7 restoration, Where to start and sill reinforcement Austin Healey 3
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
J TR6 TR6 died/ won't start Triumph 30
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
P TR6 Won't start after 10-mile run Triumph 21
jfarris TR2/3/3A Rebuilt SU Carbs - Car Won't Start Triumph 7
curdy TR2/3/3A TR3 No Start...Again. Help? Triumph 62
N TR4/4A no spark in start position Triumph 8
S TR4/4A Car Will Not Start Triumph 18
J TR2/3/3A Trying to start engine for the first time! Triumph 11
