100-6 start up issues
TangoXrayAlpha
CV19 has given me a rare chance to spend some time with my 100-6. However, my first journey was cut short when it just cut out.
The car has a Pertronix ignition fitted, and was running fine before the above happened. There's a healthy spark at the coil, but nothing at the plugs. I've looked at the Pertronix website, and checked the module as per these instructions (which seems to be working fine). Therefore, I assumed the next most likely culprit was a bad ground. I've checked and cleaned the ground from the coil to the chassis, which didn't fix things. I'm now not sure where to turn next.
I'm debating whether driving a non-power steering car can count as my daily exercise, so any help getting her going again would be appreciated!
steveg
Make sure your flex-wire ground is good between the movable and fixed distributor plates. Sometimes these become intermittant. If they're insulated the wire can break internally.
Make sure there is good ground continuity between Pertronix base plate and the chassis through the various joints and clamps of the distributor and ground strap. You may need to clean things up to help the grounding. I'd read about some UK Mini racers who traced Pertronix problems to bad grounding between distributor and chassis. I added a 3rd flex wire from the Pertronix base plate, out through the side of the distributor and directly to a connector on the chassis. Belt & suspenders.
red57
Good spark at the coil means the Pertronix is working. Not getting spark to the plugs means it is the rotor, distributer cap, or the wires.
The easiest to change is the rotor, if you have a spare. Look for cracks or a loose rivet.
On the cap, make sure the carbon spring loaded center contact is free to move in & out so it can make continuous contact with the center of the rotor.
Look for cracks in the cap.
If all those check out, it may be time for new wires (if it didn't sputter or run badly before quitting, I would suspect the one from the coil to the cap first).
If you still have the stock side entry cap, there could be corrosion where the screws go into the plug wires.
Dave
steveg
The connections in the cap between the piercing screws and cables can give out. If there's enough wire, one can trim 1/4" off the end and re-attach the cable to the screw. Some of the replacement caps had screws off-center which did a bad job of piercing the cables. Resistance (non-metallic) cables are worse in this respect.
5 How not to start a freshly rebuilt 100/6 engine Austin Healey 30
C RestoRod 100-6 Seeking Guidance... Brakes to Start Austin Healey 15
H My 100-6 Won't Start Austin Healey 27
J New healey 100 owner start up Q'S . Valve train Austin Healey 6
J Owners of my 100-4 Austin Healey 1
andrea AH 100/6 1957 Longbridge Photo Albums Austin Healey 5
H 100-6 Interior Installation Austin Healey 4
B Overcooling Healey 100 Austin Healey 13
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
Michael Oritt 100 Windshield seal Austin Healey 0
madhouse 100-Six Side Curtains Austin Healey 8
C 100/6 BN4 Soft Top Frame Austin Healey 7
Editor_Reid Healey 100 Chassis Dimensions Austin Healey 5
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
dougie Austin-Healey 100 Documentary Austin Healey 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 16
H 100-6 Austin-Healey Austin Healey 7
K 100/6 Stamped Numbers Austin Healey 6
R Wanted 100 side curtains Austin Healey Classifieds 9
HealeyRick Streamlined 100-Sixes Austin Healey 0
DerekJ Fitting a 100-Six grille. Austin Healey 10
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
G Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
S For Sale Austin Healey 100-4 Factory Parts Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey 100-4 Factory Workshop Manual on CD/ROM Austin Healey Classifieds 0
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
Lin Spruce Green Healey 100 Austin Healey 17
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
NutmegCT T-Series MG-TF and AH 100 MG 0
HealeyRick Period 100 Review Austin Healey 6
L 100/6 replacement front seats Austin Healey 7
G For Sale AH 100 parts FS Austin Healey Classifieds 8
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
B Before and After Pics Longbridge 100-6 Austin Healey 5
G For Sale Healey 100 windscreens for sale Austin Healey Classifieds 2
dougie The Larry Wilson Collection - 100-S Austin Healey 15
M 100-4 Timing Pointer Austin Healey 5
Dandare 100/6 Engine Backplate Austin Healey 4
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
N Healey 100/4 from the Bahamas Austin Healey 8
roscoe 100 harmonic balancer upgrade? Austin Healey 3
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
HealeyRick 100-6 on Leno's Garage Austin Healey 6
J 100 bn1/bn2 id Austin Healey 26
F 100 vs 100/6 Austin Healey 8
C For Sale Healey 100 for sale Austin Healey Classifieds 3
