Speedo angle drive
SwamperCa
I've been told you don't really need the angle drive at the trans when you have the OD unit. Mine currently doesn't have one, do I need it or not. I do have the OD.
Keoke
Hi ,IMOP the only way to get the speedo cable angled towards the front of the car easily is to use the angle drive. It does not matter whether there is an OVD or not.--Fwiw---Keoke
PAUL161
I know that there are some cars, (MGBs), out there that don't have the angle drives on them and they seem to work fine. But, I agree with Keoke, that it makes it easer and a nicer looking job to use an angle drive. One thing more, the spedo cable is longer on an OD car than a non OD car, in the later models. Don't know about the early OD cars. I forgot the measurements, but I think by about 4 to 6 inches. Someone correct me if I'm wrong.
tony barnhill
Great Pumpkin - R.I.P
Speedo cable for the OD transmission is longer - because it enters the transmission farther to the rear of the car...I've seen them with & without the angle drive but I prefer with.
Bruce74B
But if the angle drive is bad, can you hook it up without one to make sure that is the problem...just temporarily of course?
I speedometer just stopped running and I am gonna look at it as soon as I can, but this might be a way to find out what the problem is.
Bruce
tony barnhill
Sure - just screw it into the trans.
billspohn
Tony, if memory serves, the spigot comes out pointed at the side of the tunnel and installing a cable straight in would put enough of a tight bend that I'd fear for the long term reliability that way. What is your feeling - have you seen them run that way for high mileages?
The reason this subject is of particular interest to me is that the replacement angle drive I installed in my wife's MGC has just let go again. Had to wait until I drove it to find out - apparently she-who-must-be-obeyed does not watch that particular gauge.....
How has the quality of new angle drives been? (I hate using new parts instead of NOS - there seems to be such a high 'crap' factor on the repro stuff)
tony barnhill
I use angle drives on all my early cars but my '79 came from the factory with OD & no angle drive.
Bob Claffie
I ran without an angle drive for about 15K until I sold the car, with no problem, although I used the longer cable to allow gentler bends. Bob
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
P Help with Speedo Angle Drive Austin Healey 2
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
Gerry M TR6 Speedo Angle Drive Triumph 2
Gerry M TR6 Speedo Angle Drive Triumph 9
glemon Speedo Angle Drive Triumph 6
M Speedo Angle Drive Austin Healey 5
glemon Angle Drive Speedo Cable Different Size Ends Triumph 12
M Speedo angle drive MG 3
angelfj1 Right-Angle Speedo Drive Triumph 6
TonyPanchot "A" Type O.D. Speedo Angle Triumph 8
2wrench Speedo gear/speedo angle parts Triumph 9
R TR6 Speedo Experts: Troubleshoot question… Triumph 10
J TR6 speedo Triumph 0
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 4
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
J Wanted Original BJ 7 speedo Austin Healey Classifieds 0
algot1901 1950 Prefect Speedo Cable Other British Cars 8
George Zeck Speedo Cable? Spridgets 3
Dnickels Spitfire Speedo help Triumph 4
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
R Speedo High Beam Warning Light Color Austin Healey 14
P TR6 72 TR6 Speedo cable Triumph 2
4tecdog Speedo drive gear Spridgets 15
N Speedo identification? Other British Cars 4
F TR6 speedo gear reduction Triumph 3
S TR2/3/3A Routing the OD speedo cable Triumph 9
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
T TR2/3/3A Question on overdrive pinion & bearing assembly for speedo drive Triumph 11
Jeepster Oily speedo Austin Healey 8
Bob_Spidell Disassemble Speedo Adapter Austin Healey 2
S TR4/4A What is the routing for the speedo cable Triumph 2
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
MY66AH Speedo rebuild Spridgets 5
B TR2/3/3A Gearbox speedo drive seal Triumph 1
longbridgehealey Speedo cable from 59 Bugeye Spridgets 1
MY66AH Speedo problems Spridgets 15
doc50 TR2/3/3A Speedo WAY off... Triumph 10
Patrick67BJ8 Speedo calibration Austin Healey 22
paul9999 Speedo...just gets quicker and quicker! Other British Cars 2
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
mgedit TR2/3/3A Bouncy Speedo ... Lubrication Triumph 4
trotti Speedo ignition light Austin Healey 12
B Speedo needle Austin Healey 3
Rut MGB OD install, speedo drive gear MG 0
doc50 TR2/3/3A Speedo reads way too low Triumph 13
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
6TTR3A TR2/3/3A Speedo in KPH Triumph 21
