TR2/3/3A Routing the OD speedo cable
sp53
Routing the OD speedo cable, I have seen some pics on how the cable goes in front of the battery box and done the passenger-side by the heater nipple and along the frame, but how does the cable get to the point where it goes through the frame and through the emergency brake linkage hole. Does the cable go through one of the brake line holes with the brake line in the frame?
steve
KVH
I can only say that on my TR4 is doesn't go through any holes in the frame. It goes along the transmission, inside the hump, of course, passenger side, and bolts up the the angle drive. I bet I'm missing something. . . .
S
sp53
Maybe the body configuration is different. I just came up with what makes the best sense to me and ran it through the hole with the brake line and clipped it to the frame and poked it across straight to the trans. I do not have an angle drive maybe I am missing that or a tr3 does not use it. I think this should work.
jfarris
Steve,
My apologies for not responding to your request. I just did the same thing on my 3 when I switched from an angle drive with short cable to the long cable. I used an old thread that Randall told the correct way to route and you got it correct. Where did you get the small, half moon, clamp that holds the cable in front of the battery?> I'm temporarily using a white plastic TV cable clamp that is very ugly. My OD wires run through the top of the tunnel and have to be unplugged when the tunnel is removed, but it is not that difficult and hardly ever comes out. The folks at Mo-Ma who rebuilt and calibrated my speedo recommended going back to the original long cable. They said the angle drive and short cable has more stress and when the cable starts to go bad they can effect the speedo - mine was bouncing between 50 and 80 when driving 60. It is now smooth as silk!
Good luck!
S
sp53
I will forgive you, but could you do me a favor when you have time and measure how much lower you gas pedal is than you brake. I seem to get 5 inches on this car and think the gas pedal is bent down. The clip you want is part 74 # 589-080 those clowns at Moss told they did not know if they had it, like ok that is your answer--- but one day I saw it after I spent a couple of hours making them. The other part that is used on the OD cable is part 80# 589- 115 agian they do not they have them unless you tell them. Part 589-115 might have a too large of hole for a screw because that takes a bolt and OD cable takes a screw.
https://mossmotors.com/triumph-tr2-3-4/engine-performance/oil-system-2
peace out steve
CJD
I had to bend my accelerator pedal rod several ways. When I was done, it lined up so as to hit the back stop bolt centered, and I made it just get full travel at the carbs before hitting the stop. This made it’s resting position about the same height as the brake pedal when the brake is depressed and just engaging.
S
sp53
John did you bend the rod in the car? I did many years ago—many; I thinking if I take a vise grip with a ½ round bar slot/hole on the end and clamp it just about at the stop bolt bracket and maybe a crescent wrench on the pedal for leverage and pull up like Tarzan the rod might bend. Sure taking it out would be an easier way to bend it, but the pedals do come out friendly. Any suggestions?
jfarris
Steve,
At rest, my clutch pedal sits 1.25" higher than the brake pedal and the brake pedal sits 3" above the accelerator pedal. The clutch does not start to engage (have any resistance) until you press it about 1". See the picture. At one time, I checked my accelerator just as John did to make sure the carbs were fully opening, but have had them off a couple times since then, so this is a good reminder to look at them again.
Good luck,
STeve 1958
My clutch and brake peddles have always been at the same height on my five different triumphs. The gas is about an inch lower. I found it easy to bend the gas peddle rods by hand, in the car.
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
S TR4/4A What is the routing for the speedo cable Triumph 2
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
M BT7 Speedo Cable Routing Austin Healey 3
O TR2/3/3A TR3 Speedo Cable Routing Triumph 1
O TR2/3/3A TR3 Speedo Cable Routing Triumph 3
Tinkerman TR2/3/3A Speedo Cable Routing TR3 Triumph 12
R MGA Speedo cable routing MGA MG 2
T TR2/3/3A TR3 w/overdrive speedo cable routing??? Triumph 2
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
Walter74 Fuel Line Routing Austin Healey 7
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D BT7 Air Vent Control Cable Routing Austin Healey 0
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
Healey Nut Rear Wiring Routing Austin Healey 2
Healey Nut Wiring Harness Routing Austin Healey 5
S Routing of Hand Brake Cable Austin Healey 6
R TR2/3/3A Speedometer Routing Triumph 15
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
M TR4/4A Speedometer Cable Routing Triumph 7
dklawson General TR Fuel Line Routing Triumph 4
F Heater pipe and air duct routing BT7 Austin Healey 3
B Speedometer Cable Routing Austin Healey 9
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
TRMark TR4/4A Choke Cable Routing Triumph 3
G TR4/4A Windshield Washer Tubing Routing Triumph 1
D TR2/3/3A Exhaust system routing and middle clamp Triumph 8
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
CJD TR2/3/3A Overdrive Wire Routing Triumph 15
R Help with BJ7 front brake line routing Austin Healey 6
Csarneson Battery Cable routing pics on a BN4? Austin Healey 7
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
C routing of speedometer cable on BN6? Austin Healey 11
D TR2/3/3A Demisterr vent routing Triumph 6
Rut Brake line routing Spridgets 21
gbtr6 TR6 Need pictures of heater hose routing Triumph 0
bugedd Fuel Leak and Proper Routing Spridgets 9
J TR2/3/3A Speedometer cable routing and dash switch layout. Triumph 2
RAC68 Routing Oil Cooler Lines Austin Healey 16
AHS TR2/3/3A Fuel line to tank routing? Triumph 2
B TR6 Reverse light wiring harness routing Triumph 4
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
tinman58 TR5/TR250 oil line routing Triumph 3
C BJ8 spedo cable routing Austin Healey 2
M Right Hand Drive cable routing Spridgets 11
AHS TR2/3/3A Disc brake line routing Triumph 0
M TR2/3/3A OD wire routing question Triumph 14
G `Request for Overdrive Speemometer Cable Routing Picture Triumph 0
Patrick67BJ8 Photos Needed of Front Wiring Routing - BJ8 Phase 2 Austin Healey 11
