TR4/4A Long Speedo Cable for Overdrive--where does it get tied down?
KVH
My old cable was all burned up by my exhaust system. Is there a special way to secure that cable to frame or other areas? It seems almost too long, and I'm tempted to put a curl in it.
TR3driver
Great Pumpkin - R.I.P
Might be it is a bit long; the information I dug up says the original OD cable (for LHD TR4 w/OD) was only 89", but it seems most vendors offer a 96" cable instead.
Not sure if TR4 is the same (probably not), but IIRC the TR3 has a clip on the RH frame rail for the OD cable in addition to the one in front of the battery box.
Another trick that might help is to slit a length of old fuel line, and slip that over the cable.
HerronScott
I think he has a TR4A which should have a 504948 according to the SPC. That's supposed to be a 66" cable and should be routed like the TR6 across the top of the transmission and use the right-angle adapter. The TR6 used a 69" cable though with or without overdrive and I see that TRF supplies the 69" cable if you look-up the 504948 part.
Scott
TR3driver
KVH
KVH
I goofed up and ordered one longer than needed. I've got almost 18" too much no matter how creative I get. Is it OK to just loop it to take up the extra length? I really don't want to order a new one at this point. the loop would be loose.
TR3driver
18" would be roughly a 6" diameter loop, which IMO is too tight for long life. But I guess you could run it that way until the cable fails, and then buy the right one :D
If you don't mind possibly having to replace the angle drive as well. Those things are rather fragile in my experience, and it might well fail first if the cable starts to bind up.
sail
I'm sure your already doing this but from the drive straight forward all the way to the engine compartment. Then up and over the gearbox.
S TR2/3/3A TR3A inner speedo cable too long at trans. Triumph 5
R The long road home Spridgets 1
Y MGB An odd (and probable long-shot) request... MG 5
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
T BT7 throttle relay levers short and long Austin Healey 1
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
Michael Oritt Post- Open Roads 2002: Tahoe to MD the long way Austin Healey 19
R TR2/3/3A Restoring a 54 TR-2 Long Door Triumph 10
boxofparts TR2/3/3A My long term 30 yr project Triumph 5
K For Sale Long and short TR3 and 4A Intake manifolds Triumph Classifieds 0
Joe Schlosser Thoughts on a long traffic Light Spridgets 11
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 22
H Long Lost Midget Spridgets 0
E Long lost Sprite Spridgets 10
roscoe Leakdown test [long read] Austin Healey 11
aero3113 Healey Shop on Long Island Austin Healey 9
britlover Wanted TR4 Hood long bubble Triumph Classifieds 0
D MGB Painted rubber bumpers. How long will they hold up? MG 1
T C42 BJ8 generator long screw needed Austin Healey 2
PeterK General TR Time for a long ride Triumph 3
D After a long break.... Spridgets 6
Lotus Club SoCal Ballast Point Long Beach Social Lotus 2
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
L TR6 need help on long dead TR6 Triumph 16
Sarastro Morris Minor in Long Beach, CA Spotted 1
D TR4/4A extra long oil filter attachment stud Triumph 9
D TR4/4A flywheel bolts maybe too long Triumph 15
Sarastro Red TR3 in Long Beach, CA Spotted 0
Jim_Gruber I woke up Bugsy this afternoon after about a month long nap and he was cranky Spridgets 7
TomMull Post-War Other Herald: Holy Moly! [Why it took me so long to make the accelerator bracket] Triumph 2
Marla TR4/4A Take the long way home Triumph 11
K TR2/3/3A How long should an SU damper top up last? Triumph 22
steveg Very interesting very long blog posting - racing oil and zinc Austin Healey 44
Got_All_4 TR2/3/3A Tr6 a type overdruve in my tr3 too long Triumph 10
TomMull TR2/3/3A Long Door anyone Triumph 16
B TR2/3/3A TR3A VS TR4 Long Tube inlet manifold Triumph 8
KVH TR4/4A Long Speedometer Cable for OD Transmission Triumph 10
W Long time Spridget poster looking at BT7 Austin Healey 5
M_Pied_Lourd TR2/3/3A Long Door Project Triumph 7
A TR4/4A Short or long tie rod end levers on TR4a Triumph 6
R General TR Long Distance Trip Repair Kit Triumph 20
Willie_P TR4/4A Starting long dormant TR engine..start up procedures? Triumph 10
T TR4/4A Access to a professional sandblasting set up - why the heck did I wait so long... Triumph 4
GTP1960 TR2/3/3A How long do leaf springs last? Triumph 8
Bob Claffie MGB The first trip [long] MG 3
F Too much procrastination[maybe long winded] Austin Healey 9
drooartz MGB-GT First long drive in the GT without tire problems! MG 14
F Looking for Long Lost BJ-7 Austin Healey 2
