Speedo problems
MY66AH
I have a '66 Sprite and the speedo indicator is just spinning around but the odometer is working fine. Is it the cable or the cluster? Thanks again.
Deleted member 8987
What do you mean by "the speedo indicator is just spinning around"?
Do you mean as you drive the needle that points to the indicated speed is spinning around, faster and faster as you drive?
Odometer working means gears in trans and cable are okay enough...altho sticking cables (rusted, dirty, corroded, too much grease) can cause flicking of the needle.
But if the speedometer has failed, and you have a direct connection between the cable input through the magnets and drum to the needle, well, time to go looking for a new unit.
Opinion.
dklawson
If the needle goes all the way around the face, the gauge needs a professional rebuild. Something went wrong and now the hairspring that counterbalances the needle will be tied in a knot.... and broken.
MY66AH
MY66AH
So how does one find such a master craftsman?
Deleted member 8987
https://www.nisonger.com/
However...be prepared for some sticker shock if your needle has spun.
That generally means something like the pilot bearing has gone, the magnets have impacted the drum, spun it, breaking off the stop or zero tab, and destroying the hair springs. If it's like my speedometers.
And with Limey Limos, maybe not.
Is yours one with the calibration number on the face? That's for tyre size and gear ratio of rear axle and possibly overdrive (depends on marque).
I think I would ask around and see if someone had a similar calibration number head you could buy.
Just a thought.
drooartz
Palo Alto Speedometers (https://www.paspeedo.com) is another option for a respected repair shop. Also unlikely to be cheap.
I've never had a LBC speedo that worked. The one in my MGB is dead, as is the one in the Morris. No idea if the Bugeye one works, but somehow I doubt it. :grin:
Jim_Gruber
Speed hut fixes that issue.
Deleted member 8987
Mine works, but it's 10% off. Odo and Speedo.
I have done enough reading to know if I was to send it in, specifying what the errors were to correct, it would probably come back worse.
If it was US...1,000 RPM is 60MPH on all...you just change the gear in the trans end of the cable....NOT all the silly gears in the speedo head....and different for odo and speedo...and stupid....but I digress.
nomad
If you can get along without it for a while, flea bay is probably the cheapest option. The only spare I think I have needs to go to the shop to correct major needle bounce. I'll dig deeper to see what I can find.
Kurt.
SaxMan
The speedo in Baby Blue seems to work and is reasonable accurate, although it is subject to some bouncing at highway speeds. I greased the cable which reduced the bouncing to a tolerable level of about 5 mph. At one point the speedometer was giving me fluctuations of almost 20 mph.
DugMoney
Member
I'd send it to Nisonger as well. A little pricey, but it will come back fixed.
My temp. gauge quite working last month, so I'm going to take it out this fall and send it up.
drooartz
Just sent the big Healey speedo off to Nisonger. As a point of information, they quoted $175 with a three-week turnaround.
That's not bad at all. I need to do the speedo in my Morris (and the MGB one, and the Bugeye one...). May have to motivate to get it sent out.
RynoBoy74tr6 Speedo, Odometer,Trip counter problems.... Triumph 6
Mg_Bizzle New speedo cable problems MG 4
S TR6 Speedo problems [TR6] Triumph 5
J 74 Midget Speedo Problems MG 1
G speedo problems Jaguar 1
R TR6 Speedo Experts: Troubleshoot question… Triumph 10
J TR6 speedo Triumph 0
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 4
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
J Wanted Original BJ 7 speedo Austin Healey Classifieds 0
algot1901 1950 Prefect Speedo Cable Other British Cars 8
George Zeck Speedo Cable? Spridgets 3
Dnickels Spitfire Speedo help Triumph 4
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
R Speedo High Beam Warning Light Color Austin Healey 14
P TR6 72 TR6 Speedo cable Triumph 2
4tecdog Speedo drive gear Spridgets 15
N Speedo identification? Other British Cars 4
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
F TR6 speedo gear reduction Triumph 3
S TR2/3/3A Routing the OD speedo cable Triumph 9
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
P Help with Speedo Angle Drive Austin Healey 2
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
T TR2/3/3A Question on overdrive pinion & bearing assembly for speedo drive Triumph 11
Jeepster Oily speedo Austin Healey 8
Bob_Spidell Disassemble Speedo Adapter Austin Healey 2
S TR4/4A What is the routing for the speedo cable Triumph 2
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
MY66AH Speedo rebuild Spridgets 5
B TR2/3/3A Gearbox speedo drive seal Triumph 1
longbridgehealey Speedo cable from 59 Bugeye Spridgets 1
doc50 TR2/3/3A Speedo WAY off... Triumph 10
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
Patrick67BJ8 Speedo calibration Austin Healey 22
paul9999 Speedo...just gets quicker and quicker! Other British Cars 2
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
mgedit TR2/3/3A Bouncy Speedo ... Lubrication Triumph 4
trotti Speedo ignition light Austin Healey 12
B Speedo needle Austin Healey 3
Rut MGB OD install, speedo drive gear MG 0
doc50 TR2/3/3A Speedo reads way too low Triumph 13
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
6TTR3A TR2/3/3A Speedo in KPH Triumph 21
Gerry M TR6 Speedo Angle Drive Triumph 2
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
E TR4/4A Speedo v Tach cable Triumph 2
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
Gerry M TR6 Speedo Angle Drive Triumph 9
