TR4/4A What is the routing for the speedo cable
shoopal
After coming out the firewall, does it go over or under the trans? What if I have to change it or the angle drive? willI need to take the cover tunnel out (again)?
Thanks for looking.
Al
TR4nut
Over the gearbox not under. And yes to pulling the cover if you work on the angle drive, unless you have a separate access plate in your cover.
mgedit
Over is correct. Not sure if TR4 is different, but just changed out angle drive on my TR6 from below.
Cheers, Mike
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
S TR2/3/3A Routing the OD speedo cable Triumph 9
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
M BT7 Speedo Cable Routing Austin Healey 3
O TR2/3/3A TR3 Speedo Cable Routing Triumph 1
O TR2/3/3A TR3 Speedo Cable Routing Triumph 3
Tinkerman TR2/3/3A Speedo Cable Routing TR3 Triumph 12
R MGA Speedo cable routing MGA MG 2
T TR2/3/3A TR3 w/overdrive speedo cable routing??? Triumph 2
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
Walter74 Fuel Line Routing Austin Healey 7
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D BT7 Air Vent Control Cable Routing Austin Healey 0
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
Healey Nut Rear Wiring Routing Austin Healey 2
Healey Nut Wiring Harness Routing Austin Healey 5
S Routing of Hand Brake Cable Austin Healey 6
R TR2/3/3A Speedometer Routing Triumph 15
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
M TR4/4A Speedometer Cable Routing Triumph 7
dklawson General TR Fuel Line Routing Triumph 4
F Heater pipe and air duct routing BT7 Austin Healey 3
B Speedometer Cable Routing Austin Healey 9
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
TRMark TR4/4A Choke Cable Routing Triumph 3
G TR4/4A Windshield Washer Tubing Routing Triumph 1
D TR2/3/3A Exhaust system routing and middle clamp Triumph 8
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
CJD TR2/3/3A Overdrive Wire Routing Triumph 15
R Help with BJ7 front brake line routing Austin Healey 6
Csarneson Battery Cable routing pics on a BN4? Austin Healey 7
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
C routing of speedometer cable on BN6? Austin Healey 11
D TR2/3/3A Demisterr vent routing Triumph 6
Rut Brake line routing Spridgets 21
gbtr6 TR6 Need pictures of heater hose routing Triumph 0
bugedd Fuel Leak and Proper Routing Spridgets 9
J TR2/3/3A Speedometer cable routing and dash switch layout. Triumph 2
RAC68 Routing Oil Cooler Lines Austin Healey 16
AHS TR2/3/3A Fuel line to tank routing? Triumph 2
B TR6 Reverse light wiring harness routing Triumph 4
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
tinman58 TR5/TR250 oil line routing Triumph 3
C BJ8 spedo cable routing Austin Healey 2
M Right Hand Drive cable routing Spridgets 11
AHS TR2/3/3A Disc brake line routing Triumph 0
M TR2/3/3A OD wire routing question Triumph 14
G `Request for Overdrive Speemometer Cable Routing Picture Triumph 0
Patrick67BJ8 Photos Needed of Front Wiring Routing - BJ8 Phase 2 Austin Healey 11
