Speedo High Beam Warning Light Color
Ron WLA
I need some help with the proper color for the high beam warning light and the ignition warning light in my ‘61 BN7.
The 2004 Originality Guide (page 9) says that cars destined for “continental export” had blue warning lights for the high beam and red for the ignition warning light. My car was shipped directly to California for sale by a dealer here. Is that considered “continental export”?
I just had my speedo repaired by Foreign Speedo. The little colored lens for the high beam warning light was missing since I bought the car. Preston told me they discovered a red lens inside and he reinstalled it.
So, I am wondering if it should be blue or red? Since I have the gage out, now would be the time to make it right if I can find out what is right.
Any help would be appreciated.
Thanks
Ron Fine
Roger
Bronze
Roger,
Your cars are newer and the high beam these days is blue - do you know for a fact the '61 Healey uses blue for the high beam?
I don't have my car right now, but seem to remember the high beam may not be blue on my '59.
For a fact, I don't know that a 61 US-bound Healey has a blue high-beam light. However, I am an old Englishman and had several BMC cars of that ERA, from 59 onwards, and in UK at least they were blue. Didn't have a Healey though.
Rob Glasgow
I have a 1960 BT7 that I've owned since 1963. It was imported directly to California. Both ignition and high beam lights had red lenses. The Drivers Hand Book that came with the car confirmed the high beam lens was red. I would be surprised if the 1961 was different than mine. High beams were changed to blue at sometime in the future but I don't know the change point.
DerekJ
Direct quote from my original 100-Six handbook.
’Main Beam Warning Light: A red glow appears when the headlights are switched on, with the two beams straight ahead. The light goes out when the headlights are dipped.’
steveg
Well there you are then. Apologies!
Not necessary! All in the spirit of answering the original question. On these British Car Forums I love exploring the arcane questions about our old LBCs! Once again, we're medieval monks poring over the ancient manuscripts, perhaps looking for the answer on turning base metal into gold.
John Turney
... Once again, we're medieval monks poring over the ancient manuscripts, perhaps looking for the answer on turning base metal into gold.
Somehow it seems to be more work and money than the price of gold. Thankfully, it's good entertainment.
Rob Glasgow
I had to laugh at Ron's original post. I too found the red lens disk in the bottom of the speedo can when I opened it up years ago. I'm not clear if the lenses were glued in or just a press fit, but obviously they were subject to falling out. I can count on one hand the number of Smith speedos and tachs from the era that still have the lenses. Doubt if I've ever seen one on the gauges sold on eBay.
R TR6 Speedo Experts: Troubleshoot question… Triumph 10
J TR6 speedo Triumph 0
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 4
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
J Wanted Original BJ 7 speedo Austin Healey Classifieds 0
algot1901 1950 Prefect Speedo Cable Other British Cars 8
George Zeck Speedo Cable? Spridgets 3
Dnickels Spitfire Speedo help Triumph 4
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
P TR6 72 TR6 Speedo cable Triumph 2
4tecdog Speedo drive gear Spridgets 15
N Speedo identification? Other British Cars 4
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
F TR6 speedo gear reduction Triumph 3
S TR2/3/3A Routing the OD speedo cable Triumph 9
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
P Help with Speedo Angle Drive Austin Healey 2
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
T TR2/3/3A Question on overdrive pinion & bearing assembly for speedo drive Triumph 11
Jeepster Oily speedo Austin Healey 8
Bob_Spidell Disassemble Speedo Adapter Austin Healey 2
S TR4/4A What is the routing for the speedo cable Triumph 2
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
MY66AH Speedo rebuild Spridgets 5
B TR2/3/3A Gearbox speedo drive seal Triumph 1
longbridgehealey Speedo cable from 59 Bugeye Spridgets 1
MY66AH Speedo problems Spridgets 15
doc50 TR2/3/3A Speedo WAY off... Triumph 10
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
Patrick67BJ8 Speedo calibration Austin Healey 22
paul9999 Speedo...just gets quicker and quicker! Other British Cars 2
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
mgedit TR2/3/3A Bouncy Speedo ... Lubrication Triumph 4
trotti Speedo ignition light Austin Healey 12
B Speedo needle Austin Healey 3
Rut MGB OD install, speedo drive gear MG 0
doc50 TR2/3/3A Speedo reads way too low Triumph 13
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
6TTR3A TR2/3/3A Speedo in KPH Triumph 21
Gerry M TR6 Speedo Angle Drive Triumph 2
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
E TR4/4A Speedo v Tach cable Triumph 2
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
Gerry M TR6 Speedo Angle Drive Triumph 9
F Speedo problem BT7 - cable rotates but speedo does not Austin Healey 25
Gerry M TR6 Speedo stopped working Triumph 6
M TR2/3/3A TR3 Speedo cable Triumph 4
M Speedo pinion on Overdrive Austin Healey 1
G MGB Tach and speedo rebuild. MG 3
