Spark Plug Issue on a 100
tontonene
Member
I recently pulled my plugs on my 100 and noticed the two outside (1 and 4) looked normal and the two inside (2 and 3) looked like the cylinders were running rich. Anybody know what is happening? Looks like a fuel mixture issue.
Dave Russell
Yoda - R.I.P
Not likely a carb related problem. Cylinders 1&2 are supplied by the front carb, and cylinders 3&4 are supplied by the rear carb.
Maybe no problem at all. The center cylinders can run at slightly different temps than the outer ones. If the heater control valve is open, some coolant bypasses it's normal flow path & flows from between the center cylinders back to the water pump.
tontonene
tontonene
Member
Thanks, Dave. I am not too worried since the car is performing properly. Just thought it odd that the plugs were not all the same.
steveg Accidentally deleted Spark Plug Issue thread Austin Healey 2
steveg Spark Plug Issue Austin Healey 54
Morris Spark plug issue??? Spridgets 35
CARSINC Spark plug thread size Spridgets 2
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
PAUL161 T-Series Odd spark plug encounter! MG 10
K TR2/3/3A Testing spark plug wires..... Triumph 11
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
K TR2/3/3A Spark Plug Gap? Triumph 4
K Numbered Spark Plug Boots? Austin Healey 27
B Spark Plug Wire Caps Austin Healey 16
B TR6 Spark plug gap Triumph 5
toysrrus TR6 Spark plug question Triumph 23
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
G Correct spark plug ends - early BJ7 Austin Healey 1
R BJ7 spark plug threads Austin Healey 17
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
S TR2/3/3A Spark plug threads Triumph 10
R '60 3000 Spark Plug recommendations Austin Healey 6
D TR6 Spark Plug Triumph 8
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
dcoplan Spark plug and oil change question Spridgets 9
H BJ8 spark plug reach Austin Healey 32
Jer chasing spark plug threads on head? Spridgets 8
R Spark plug thread Triumph 2
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
D Spark Plug Gap Austin Healey 10
M Restoring proper order to spark plug wires Triumph 36
W Source for spark plug terminals Spridgets 9
af3683 TR2/3/3A TR3 Spark Plug Wire Question Triumph 11
JPSmit Quick Spark plug question Spridgets 10
Got_All_4 TR2/3/3A TR3 spark plug wire problems Triumph 3
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
K Old School Spark Plug Road Test? Triumph 6
Musicman Spark Plug Wires Triumph 10
toysrrus TR2/3/3A Spark Plug Recommendation for a TR3: Triumph 9
T Normal/good OHM resistance through spark plug wire Triumph 17
M Carbon fouled spark plug Triumph 27
M Spark plug heat range Triumph 4
J Spark Plug life Triumph 24
W Oil leak around spark plug Triumph 6
L Spark Plug Wires Triumph 12
AUSMHLY Spark plug wires affecting tachometer? Austin Healey 16
K TR2/3/3A Spark plug gap TR3? Triumph 1
J TR2/3/3A Spark Plug Gap for TR3A Triumph 3
aeronca65t Spark Plug Cross Reference Restoration & Tools 3
