Spark plug and oil change question
dcoplan
Member
Not sure how old the plugs and cables are on my '60 Bugeye so thinking of just going ahead and replacing them. What are recommended plugs and cables? Want to get the best for my car but don't want to needlessly spend money just for a brand name.
Also, I've read that oil can be changed every 5,000 miles. Do you all agree or do you do it sooner?
Dan
Gerard
Dan
Which engine do you have? Original 948, 1275...???
dcoplan
dcoplan
Member
Thanks. Any recommendation for replacement cables or will anything do? Or should I just keep what I have? Car is running fine now, but if I can add better performing components that don't alter the car, I will.
Gerard
Hard to say since I don't know the condition of what you have. If you mean new spark wires, there are a variety of choices. I usually go with what is available from one source. I would also look at the other ignition bits, i.e. points, cap, rotor, etc. Personally, I like the improvement electronic ignition makes. Bigger improvements and come from that and a rebuilt/recurved distributor. You have a bushing that wears in the shaft that will cause a wobble. Getting rid of that on a points distributor can make a big difference, but has little to no effect with EI. (another advantage of going EI)
If you want to message me off-list or to my direct email, I can put a package together for you.
Pythias
You can also check with Jeff at Advanced Distributor.... Both he and Gerard will give you the straight scoop... You'll want his "red" rotor and it's the only place I know to get brass caps.
JPSmit
And, if you don't know about zddp (zinc) and oil, google, read all 10000 articles.... (OK, read one - and make sure you get proper oil)
AN5Sprite
And...5,000 mile oil changes are way to far for a 50+ year old car. I say much, much sooner than that. Especially if: You don't drive much, take short trips, have a mechanical fuel pump, the list could go on...For oil I'd recommend Valvoline VR1 20/50.
Boink
Bronze
Realistically, you might be changing your oil as a function of TIME not miles... but this depends on how much you drive. Many don't put on but a few thousand per year (at best) and in that case I'd be changing my oil once per year (and some would say more). I'd certainly not go more than 2500 miles.
W Oil leak around spark plug Triumph 6
B TR6 Spark Plug - oil fouling '73 TR6 Triumph 6
CARSINC Spark plug thread size Spridgets 2
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
PAUL161 T-Series Odd spark plug encounter! MG 10
K TR2/3/3A Testing spark plug wires..... Triumph 11
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
K TR2/3/3A Spark Plug Gap? Triumph 4
K Numbered Spark Plug Boots? Austin Healey 27
B Spark Plug Wire Caps Austin Healey 16
B TR6 Spark plug gap Triumph 5
toysrrus TR6 Spark plug question Triumph 23
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
G Correct spark plug ends - early BJ7 Austin Healey 1
R BJ7 spark plug threads Austin Healey 17
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
steveg Accidentally deleted Spark Plug Issue thread Austin Healey 2
steveg Spark Plug Issue Austin Healey 54
S TR2/3/3A Spark plug threads Triumph 10
R '60 3000 Spark Plug recommendations Austin Healey 6
D TR6 Spark Plug Triumph 8
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
H BJ8 spark plug reach Austin Healey 32
Jer chasing spark plug threads on head? Spridgets 8
R Spark plug thread Triumph 2
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
D Spark Plug Gap Austin Healey 10
M Restoring proper order to spark plug wires Triumph 36
W Source for spark plug terminals Spridgets 9
af3683 TR2/3/3A TR3 Spark Plug Wire Question Triumph 11
JPSmit Quick Spark plug question Spridgets 10
Got_All_4 TR2/3/3A TR3 spark plug wire problems Triumph 3
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
K Old School Spark Plug Road Test? Triumph 6
Musicman Spark Plug Wires Triumph 10
toysrrus TR2/3/3A Spark Plug Recommendation for a TR3: Triumph 9
T Normal/good OHM resistance through spark plug wire Triumph 17
M Carbon fouled spark plug Triumph 27
M Spark plug heat range Triumph 4
J Spark Plug life Triumph 24
L Spark Plug Wires Triumph 12
AUSMHLY Spark plug wires affecting tachometer? Austin Healey 16
K TR2/3/3A Spark plug gap TR3? Triumph 1
J TR2/3/3A Spark Plug Gap for TR3A Triumph 3
aeronca65t Spark Plug Cross Reference Restoration & Tools 3
tahoe healey Champion spark plug testor Restoration & Tools 25
