Size of Nut for Steering Wheel..driver not include
Bruce_B
Does anyone know the size of the size that holds that standard steering wheel onto the standard
'59 BE car? Need another one. I put the original one in a save place.
thanks..
Jim_Gruber
They are available from Moss and VB. Order both sizes as they are cheap and they sent me the wrong one the first time. Careful about those threads. They strip real easily. Don't ask me how I know.
Jim_Gruber
Oh and you want to use those nuts from VB or Moss as if you cross thread the very soft metal nut, it usually goes before the steering column. So if you do as I did, I found a thread file at Sear Hardware that allowed me to straighten out what I screwed up.
jlaird
You got that correct Jim, I think we all know about those soft threads on the shaft now.
Jim_Gruber
My solution Jack was scoring a spare column off of a '68 that was being parted out. In the back of the garage complete with a trashed steering wheel. One of these days I'll get around to pulling off the old wheel and replacing the steering shaft.
Bruce_B
Bruce_B
As I said Steve....driver not included. LOL
Good news is I found the original. It was in the plastic bag that contained the horn push button and the spring connector. (actually where it was supposed to be).
GeorgeC Steering wheel nut size? Spridgets 3
Rut TR4/4A steering shaft/nut thread size Triumph 5
R TR4/4A 66' TR4a irs, steering nut size Triumph 13
M steering wheel nut size. Triumph 10
budk1953 Steering wheel nut size Spridgets 2
R Vixen 2500 Lug Nut Size? TVR 5
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
J Nut size for BJ8 center console trim piece Austin Healey 8
C Size of axle bearing nut Austin Healey 11
M 948 Pulley Nut Size Spridgets 1
RJS TR4/4A Rivet-Nut Size Triumph 0
J MGA MGA rear axle bearing nut size MG 0
M Front Bumper Nut size Spridgets 2
justin_mercier Wedge TR7 / 8 alloy wheel lug nut shank size / length? Triumph 13
abarth69 Early BN1 Axle Nut Size Austin Healey 1
C Hex. nut size? Austin Healey 1
Tinkerman Starter Terminal Post Nut Size Triumph 14
S What size is your nut?? MG 3
boxfullofyertoys Rear hub nut size Spridgets 10
bcliff Spindle nut size? MG 2
tahoe healey starter nut size Austin Healey 6
B 1500 Crank Nut Size? Spridgets 15
chicken What size spanner for the crankshaft nut Austin Healey 5
D rear hub nut size? MG 11
73MidgetLigon Lug nut size for 73 MG Midget Spridgets 2
Baz Brake pipe nut size? MG 13
mbrooks 100-4 crankshaft nut size? Austin Healey 1
2wrench Describe thumb nut size and thread on speedo stud Triumph 26
vping Size of my nut... MG 17
T Mini drive shaft nut size. British Motor Corp 2
mbrooks BN2 front wheel hub nut size? Austin Healey 1
Patton Cap Nut on H4 SU Lid Size? Austin Healey 11
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
CARSINC Spark plug thread size Spridgets 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Bayless What size battery for my '67 Sprite? Spridgets 5
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
S TR2/3/3A Vacuum Advance Union Size Triumph 1
T Radiator Hose Size Austin Healey 2
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
Joel Lester TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
B Exhaust Pipe Size Austin Healey 26
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
Healey Nut TR6 Headlight size Triumph 58
MadRiver TR6 Emissions Hose/Tubing Size? Triumph 2
JPSmit Not quite an LBC - but the size might be close :) Restoration & Tools 3
B TR4/4A Oil Drain plug size Triumph 14
