1500 Crank Nut Size?
JPSmit
Morris
1 7/8"
You can pick on up in a kit with other large sockets at Harbor Freight for about $50.00.
Morris
I guaranty a 1 7/8" will work. And they are much easier to find.
Jim_Gruber
So a place Like Tractor Supply, Farm & Fleet has large sockets in that size for < $10.00 each. Farmers need large tools to get off their big nuts. Or something like that. What's that joke about punnctuation in the proper place.
JPSmit
although, I went to do exactly that - with a list of three sockets - Crank/ Rear Bearing/ Nut for Oil filter spinner (and later nut on rear axle/ diff seal) for about $15 more I got a complete 3/4 drive socket set - here at Princess Auto, (not unlike Harbor Freight) - I've since found a ton O uses besides impressing the heck out of my friends
B
blkcorvair
Harbor Freight it will be. especially since there's two on sale less than $50. Anyone in the same boat should endulge now as well. Good deals.
i bought mine at sears, that way i only buy it once. I am glad that i did too...that poor 12 pt chrome went thru the fires of Satan's forge at the working end of a 4 foot cheater. Then all of a sudden the crank nut, it just spun off...go figure.
in fact i think the same "yo yo"" that tightened that nut also did the oil filter on my Toyota last time...
mark
bugimike
/bcforum/images/%%GRAEMLIN_URL%%/lol.gif That guy gets around doesn't he? He must sneak into peoples garages late at night and work his mischief!! /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
JPSmit
Here he works his magic around the house also, around here, my wife calls him honey, dear, John, and a few unmentionables /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
Morris 1500 crank/pulley nut removal Spridgets 39
T MG Midget 1500 crank shaft pulley Spridgets 0
dklawson Spitfire Crank Endfloat and Oil Pumps - Spitfire 1500 Triumph 9
D MG Midget 1500 Crank Bolt MG 0
D MG Midget 1500 Crank Bolt Spridgets 4
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
JPSmit 1500 slave cylinder question Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
Rut 1500 gas pedal for sale Spridgets 7
