Repair Advice
PSandiford
I'm deciding if I should bring my Caterham 7 1600GT (Crossflow) up to the Salt Lake area. It has been stored for 10 years and needs a good British Ford mechanic's love. Any in the area I can rely on?
Bruce Bowker
Can't say I know anyone in your area but get it running. Most fun car I have ever driven.
Bruce
P
PSandiford
I gave myself laugh lines from smiling the 50k miles I drove Cate before I went overseas. I am Jones'n for my 7 fix now that I'm back.
TypeRboy
Probably a good idea to do most of the work yourself. What with the electrical, brakes and tuning, there are a few hours ( like maybe 20 ) of work there, and at current rates you could spend a fortune.
Better you should pull the brakes apart yourself, as well as change the points, plugs, oil and the like, and clean all the electrical connections. Maybe throw in some new tires while you are at it. Then if it runs poorly, flip it up to your guru. Overall the less he has to do, the more that you will save!
Remember, workmanship is always better when it's for love, not money! /ubbthreads/images/graemlins/driving.gif
Hegg
I'm in Salt Lake City and have not yet come across someone that's expert in that area. I have an Elan +2 which isn't quite the same of course, but same theory applies.
I work on mine myself and enjoy (nearly) every minute!
Super 7
I can't think of an easier motor to work on than a crossflow, except for the part about the carbs blocking easy access to the distributor.
Salt Lake is a big city. I'm sure there are a number of competent mechanics there. Sevens are super easy to work on.
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
W Bonnet repair/replacement advice Spridgets 18
C Any help or advice for accident repair?!? Austin Healey 15
M Door weatherstrip repair advice needed MG 4
M BE Body repair advice Spridgets 4
M_Pied_Lourd TR2/3/3A TR3A Inner Sill Repair Question/Advice Triumph 95
spiny rust repair advice - rear chassis bit Spridgets 17
C Soliciting opinions, advice for frame repair Triumph 9
Brosky Need Transmission repair advice Triumph 1
bmurphy7369 Need some rust repair advice for Series III XJ6 Jaguar 8
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
B TR6 Thrust face repair Triumph 1
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
C TR2/3/3A Frame repair and value Triumph 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
B Windscreen Motor Repair Restoration & Tools 6
O Jaguar rear window trim repair Jaguar 1
G Smith's temp gauge repair Restoration & Tools 4
O TR2/3/3A Good Repair Shop In New Hamphire Triumph 2
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
H TR4/4A Fender/Wing repair how to do Triumph 5
H TR4/4A Advise asked for front repair Triumph 1
Bayless How to repair broken vent window studs? Spridgets 1
AngliaGT MGB-GT Gauge Repair Recommendations? MG 4
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
D TR2/3/3A TR3 repair in Cincinnati Triumph 0
S TR2/3/3A Frame repair. Triumph 47
BritBite Transmission Repair Austin Healey 8
volunteer Wanted: Brake Master Cyl. Repair Kit for Daimler DS420 Other British Cars 18
M Capillary Tube repair Spridgets 4
D General TR Frame repair - recommendations for NJ area Triumph 3
S TR2/3/3A wire repair Triumph 7
SteveTheBrewer Spitfire More rust repair Triumph 1
M BJ8 Inner Body Panel Repair Austin Healey 2
Editor_Reid Leather Seat Repair Austin Healey 5
AngliaGT At a Local Repair Shop Spotted 1
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
J Steering Wheel Repair Austin Healey 32
F TR2/3/3A starting scuttle repair Triumph 27
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
F TR2/3/3A Dash repair Triumph 7
D Steering Wheel Repair Austin Healey 2
Michael Oritt Trafficator repair and refinish recommendations Austin Healey 6
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
T Speedometer Repair Problem Austin Healey 5
J TR2/3/3A TR3A gas tank repair Triumph 7
Upland Tonneau cover repair Spridgets 2
F TR2/3/3A Rear sheetmetal repair Triumph 73
Patrick67BJ8 HD8 Carb Repair Austin Healey 15
