Rear Diff oil suggestions?
VelodromeRacer
Hay all,
I have recently purchased a 1959 Bugeye vintage racer.
I am changing out the stock rear axels and adding double bearing hubs, it has a welded 4:22 rear end right now and I have an additional 4:55 if I need it but...
What gear oil do you suggest that I run in the diff with?
Where can I find a good set of race brake shoes as well for the rear brakes?
Other than that, I am replacing the front swivels, the car has a great race prepped 948!
I'll start racing next year, testing at Putnam Park this October 5th,
Thanks,
Tim Hollister
Congrats and welcome to the fun!!
Regarding rear end oil, I use Valvoline 80W90 in both my race cars. I've used it with welded gears and also with a Quaiffe differential. Works good.
I do recommend you stay away from the synthetics for this application. The synthetics seem to invent ways to get out of the rear end housing. If you do try the synthetics, have some good old fashioned dinosaur oil available to replace it with.
Tim
JerryB
Tim is right in suggesting GL4 or 5 instead of synthetic.
If you are quite Spridget rear housing conversant and have the fix on lube migrating , then you can use a synthetic as you might pick up a small amount of power.
Carbotech in Florida did make a sintered shoe for the stock drums but they no longer do. You might check w/ them however as this was last years news. 877-899-5024. Rumor on the beach is that Metal Frictions in Seattle does also.
Michael Oritt
I use an inexpensive 75 or 80-90 differential oil with STP mixed 3:1.
Carbotech is located in Shelby NC and makes a great lining--my Elva has drums front and rear and they will take me through a season plus.
VelodromeRacer
VelodromeRacer
Also, from what I have heard others say, run race pads on the front and stock shoes on the rear??
Does that make any sense either?
Bugeye58
Well, you could probably do that, but I think you'd be changing a lot of brake shoes. Of course, that depends on what tracks you plan on running, too. Some are a lot easier on brakes than others. Mid-O is fairly easy , Blackhawk will use more brake. Waterford Hills is tough on brakes, as it's tight and twisty.
You can also go the disc brake on the rear route.
Jeff
JerryB
"""""Speedwell has Velvetouch rear shoes, which is what I was running."""""
They are the Carbotech pieces....he MIGHT have some left. $185 a set .....ugghhh.
""""""Does that make any sense either? """"""
depends on whether you want brakes or good brakes.
If you have to use o.e. size calipers and rear drums, AND you want a maximum effort car, you want maximum pads and shoes. Most vintage clubs wont accept rear discs on a Spridget. If you have correct brake bias you WILL smoke the rear shoes if they are organic. You MIGHT consider not using the brakes...they only slow you down.
""""""""""I use an inexpensive 75 or 80-90 differential oil with STP mixed 3:1. """""""
Uhhhh.....I would use a very good quality GL rated gear lube without any additives unless you are using a clutch type posi.
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
Dudly Rear Diff Oil Triumph 11
Shinsen774 Rear Diff Gear Oil Change Interval MG 2
wangdango '67 XKE rear diff? Jaguar 2
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
A TR4/4A Changing rear diff seals Triumph 15
Gordon_Dedrick TR2/3/3A Drippy Rear diff cover Triumph 6
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
Willie_P Quick question: rear diff TR 3/4 Triumph 6
Willie_P rear diff crownwheel help Triumph 3
tinman58 TR2/3/3A TR3a rear Diff seal Triumph 8
D Spitfire spitfire diff and rear spring Triumph 9
M Rear diff. bearing ID Spridgets 2
pjsmetana Spitfire Rear Diff, Spitfire Questions Triumph 16
H IRS diff rear mounting bracket Triumph 0
J 100 rear diff - nut torque Austin Healey 4
N Rear Diff mounts upgraded Triumph 2
D TR4/4A TR4 rear diff pinion seal Triumph 4
W used rear diff Triumph 2
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
