Newkie
Hey, I am putting my 73' B roadster back together, and I have a few questions on the wiring of the Headlights, and the inserting of the parking/turn signal lights.
First, I had a little problems with the wiring for the headlights because of:
1)I didnt label them when I took them out.
2)I cant make out all the colors of the wires, so its not as simple as hooking up color to color. I think I almost have it, but one headlight seems to come on when you put the switch in the parking light location, or middle toggle.
Now, the parking lights seem to have 4 studs coming out the back and only 3 holes in the fenders? Two for the back nuts to secure the light, and two coming through from the lenses that holds the lense onto the bezel. I took the lights off, so I dont know why things look different to me while putting them back on. I will send a picture or two if I still cant get an answer to this dilema.
I assume all 4 studs should have a hole, so you can put the bezel flush with the fender.
Thank you
Newkie
Thank you
Newkie
