Parking Light/Tail Light Problem
conehead53
I recently removed and refinished the wood instrument panel on my 76 TR6. Upon re-installation I was discouraged to find my parking lights and tail lights do not work as before. I am sure I reconnected every wire I removed. I have brake lights, turn signals, back-up lights and hazard lights---but not front parking lights or tail lights. Any idea what I may have done wrong?
Administrator
Boss
You may well have connected every wire as before, but with old British wiring (even not so old) connections can get very flakey. I would first check the connection for continuity from the switch to the lights. It is most likely that the connection at the switch is at fault. I'd make sure the connector at that point is well connected to the wire and that both the connector and the switch are clean. Should be fairly easy to find. Slight possibility the problem could be elsewhere, but I start by ensuring that the connection at the switch is sound and clean.
C
conehead53
Basil, Thanks for the information. After looking for over a year, I purchased my 76 TR6 several months ago, Although it was 80% restored, my TR6 still has things to work on, which I find very enjoyable. However, I am a real beginner and I am always looking for advice. I belong to a British car club that meets monthly, and up until now that has been my main source of information. Thanks again.
Administrator
Boss
Cool. Electrical on old British Cars are a common source of frustration. Just be sure when you put electrical connections back, to clean them as good as you can (you can buy connection cleaner at radio shack).
philkile
The best thing I've found for this is TarnX(you know, that snake oil you see advertized on TV). Amazingly, it's actually one the few things hawked that way that really works as advertized. All you need do is immerse the entire connector body (time varies depending on how green and cruddy the connections are), rinse with clean water and blow dry with compressed air. I've done many connections this way and to date have not had any subsequent repeat failures.
Phil
C
conehead53
Thanks for the information. It was simply a bad connection and cleaning must have dont the trick. All is well and working now.
NutmegCT TR2/3/3A Parking light fun - TR3A Triumph 38
D TR2/3/3A wiper motor parking? Triumph 17
TomMull TR2/3/3A Parking brake: Lesson learned? Triumph 8
D Parking Brake Adjustment Austin Healey 2
M Windscreen Wipers Parking Spridgets 4
tr6nitjulius General TR TRIUMPHest 2019 Register# Reserved Parking Space# Triumph 0
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
G TR4/4A Front Parking Lamps Wiring Question Triumph 5
S TR2/3/3A Wiper Motor Parking Question Triumph 8
TomMull TR2/3/3A Parking brake cable length Triumph 3
K TR2/3/3A More electrical....parking lights?... Triumph 2
B Mini Windscreen Wiper Parking British Motor Corp 3
T TR2/3/3A wiper motor parking Triumph 7
Patrick67BJ8 1967 Phase-2 BJ8 - Front parking & turn signal lights alignment Austin Healey 8
RickB All 4 parking lights dead, fuses all good? Spridgets 6
T TR2/3/3A TR3b parking lamps Triumph 2
wingsandwheels TR6 TR6 wiper motor parking Triumph 1
T T-Series TF Parking Brake Disassembly Advice Needed MG 2
O TR2/3/3A TR3 Headlite Trim Rings and Front Parking Lite? Triumph 10
JPSmit Parking garage spot - REALLY lousy pics Spotted 6
J TR2/3/3A tr3 notchy steering in parking lots Triumph 12
PatGalvin Parking Brake Rebuild Triumph 5
Brooklands Seen in the public parking garage in St Augustine Jaguar 4
Morris OT: Spent the night in a parking lot... Spridgets 2
tweety Parking Brake Adjustment Spridgets 3
B How to install tail and parking lights?? Austin Healey 10
M Wipers parking in the Up position Spridgets 11
D Front parking lamps and side markers? Triumph 10
Newkie Parking and Headlight problems MG 8
PeterK Well, the parking brake works ... Triumph 12
Dadandson Adjusting the Parking Brake Spridgets 12
tony barnhill Harbor Freight Parking Lot Sale... Restoration & Tools 27
Aeroken Parking Brake Cable Triumph 6
19_again bright parking lights MG 6
V 1969 Mini Parking Lights British Motor Corp 6
jjbunn Windscreen Wiper Parking MG 10
fmichaels 67 parking/turn signal lights Spridgets 8
10musketeer Hmm. Parking Lights Spridgets 4
Russ Austin Wife's not happy, No parking space! Triumph 8
W Parking Lights Spridgets 12
J Hand brake/ Parking brake MG 6
J Parking lot races Triumph 15
Bruce Bowker Parking lights Other Cars 12
A parking break? MG 2
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
D TR2/3/3A 3D printed tail light Triumph 12
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
B Positive-Ground LED Light Strip Austin Healey 8
bigjones TR2/3/3A Rear tail light not budging Triumph 5
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
