overdrive oil leak
higgins
My overdrive is slightly leaking oil /ubbthreads/images/graemlins/cryin.gif
The leak stems from the Core Plug (next to the drain plug)
Is there anyway this can be sealed off without having to open the entire overdrive?
healey3000
Hi Higgins,
perfect cleaning with brake cleaner and outside sealing with ELRING DIRKO silicon worked fine for me in that area. Surely only a temporary fix but it is already lasting for over 3 years.
Best regards
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
4tecdog BJ8 Overdrive oil leak Austin Healey 6
RickPA Overdrive Oil Pressure Austin Healey 8
D Overdrive Stops Working After Oil Change Austin Healey 26
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
R Gearbox and Overdrive Oil Level Austin Healey 18
Joe_Healey TR5/TR250 Overdrive Gear box oil Triumph 8
G Transmission with Overdrive - Which Oil to Use Austin Healey 30
G Gearbox and overdrive oil change Austin Healey 15
S TR4/4A What kind of oil in overdrive gearbox? Triumph 5
D Overdrive Leaking Oil Austin Healey 4
B Overdrive Oil Pump Installation Question Austin Healey 10
R draining oil from overdrive on a BJ7 Austin Healey 6
Lukens Best gearbox oil... with overdrive? Triumph 16
L Overdrive and tranny oil Austin Healey 19
M correct gear oil for bj8 trans and overdrive ???? Austin Healey 5
PAUL161 72 Overdrive rear oil seal question. MG 0
LBCs_since_1988 Overdrive hungry for oil Triumph 5
Monark192 MGB-GT 67 GT Overdrive trans oil change question. MG 6
R Filling overdrive oil on BJ-7 Austin Healey 5
TimK Overdrive with no oil pressure - BN7 sideshift Austin Healey 13
H Where is the Overdrive Oil Drain Plug and Filter? Austin Healey 2
S Oil change in Gearbox & overdrive - extra parts ? Austin Healey 4
G Misc Questions re Overdrive and Exhaust + Up-date on Redline Oil Austin Healey 7
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
