BJ8 Overdrive oil leak
4tecdog
Hi
In process of removing transmission on a 65 BJ8 to and noticed a pool of oil sitting around the output
shaft lock nut when I released the propshaft does this mean the rear oil seal has failed or is it possible for the oil to seep along the coupling splines and out into the gap between the couplers of the overdrive and propshaft ? Also is it possible to replace the rear oil seal by just removing the coupling and not having to strip down the O/D.
Any help would be appreciated by a new custodian of this beautiful car.
Br
Rob
Healey Nut
Sounds normal , it's the automatic rustproofing system they installed on every Healey .
4tecdog
4tecdog
Sounds good but if the tranny is coming off any
way would it be prudent to replace the seal
thanks for your reply.
Keoke
Unequivocal YES!! -:applause:
BJ8Healeys
Hi
...is it possible to replace the rear oil seal by just removing the coupling and not having to strip down the O/D.
Br
Rob
Yes, it's possible to replace the rear oil seal without stripping down the overdrive. It drives in from the rear after you remove the universal joint coupling. The old seal can be pried out, or drilled for self-tapping screws and then pulled out by gripping them. Drive in the new seal until it is flush with the O/D casing.
Congratulations on becoming the latest custodian of a BJ8! You have excellent taste in automotive machinery. Now, please allow me to add your car to the BJ8 Registry to join the other 8,733 cars already there (more than 49% of total BJ8 production), or allow me to update the ownership history in case I already have it. You can do that by going to the Austin-Healey homepage of the forum and clicking on the BJ8 Registry button at the top.
Thanks!
Side note: Years ago, I had to replace one of the yokes; don't recall if it was the (front) one on the propshaft, or the one on the O/D, and the grizzled old machinist at one of the local shops said it was the same as used on Volvos of the era. We used the 'Volvo' one and it was a perfect match; my guess is Jensen made these or Austin and Volvo used the same source. The Volvo P1800 body was built by Jensen IIRC (and early Volvos use SU carbs).
4tecdog
4tecdog
Thanks for your reply and info much appreciated and yes I have added my car to your registry, that's impressive 49%��
M correct gear oil for bj8 trans and overdrive ???? Austin Healey 5
S BJ8 Overdrive Issue Austin Healey 6
S BJ8 Overdrive issue Austin Healey 10
BJ8Healeys For Sale Rebuilt BJ8 overdrive unit for sale Austin Healey Classifieds 0
Airwave BJ8 overdrive stops working after a while driving Austin Healey 17
M Overdrive In-Op AH BJ8 1967 Austin Healey 11
S Overdrive solenoid problem on a BJ8 Austin Healey 3
D Overdrive problem when raining - bj8 Austin Healey 23
S BJ8 Sputtering at High Engine Speed and in Overdrive Austin Healey 36
davidb AH 3000 BJ8 overdrive problems Austin Healey 11
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
AH67 BJ8 OverDrive Austin Healey 5
M overdrive bj8, smoked Austin Healey 1
D BJ8 Overdrive Switch on gear leaver top Austin Healey 2
R BJ8 overdrive intermittent Austin Healey 11
bighealeysource overdrive not disengaging right on my BJ8 Austin Healey 7
Ed_K Overdrive solenoid rubber piece on a BJ8 ? Austin Healey 2
specialsports Help Healey BJ8 overdrive just stopped working? Austin Healey 5
A BJ8 Overdrive Austin Healey 3
Steve P. Value of Healey BJ8 overdrive? Austin Healey 2
JamesD BJ8 Top Frame Bumpers Austin Healey 6
AUSMHLY BJ8 Driveshaft Installation Austin Healey 10
M BJ8 Inner Body Panel Repair Austin Healey 2
crispy BJ8 Front Suspension Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
BJ8Healeys Original Metallic Golden Beige BJ8 for sale Austin Healey Classifieds 0
M BJ8 Seat Thickness Austin Healey 6
D BJ8 Headlight Rims Austin Healey 0
B RHD BJ8 Throttle Control Rods Austin Healey 9
J BJ8 Radiator Fan Austin Healey 12
H BJ8 Heater Valve/Control Tap Austin Healey 3
R BJ8 Upholstery Austin Healey 5
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
T BJ8 Drain Channel Removal Austin Healey 2
B BJ8 Phase 1 Electrical Diagram Austin Healey 15
M For Sale BJ8 Tonneau Cover Austin Healey Classifieds 8
R Distributor: Reassembling BJ8 Engine Austin Healey 5
lbcspinners BJ8 chassis number ending with suffix "G" [??] on BaT Austin Healey 11
R New Engine mountings BJ8 Austin Healey 1
T BJ8 carpet Austin Healey 2
R Cylinder head gasket BJ8 Austin Healey 32
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
BJ8Healeys For Sale 1965 BJ8 for sale Austin Healey Classifieds 0
M Getting behind the dash on BJ8 Austin Healey 4
J BJ8 flywheel take some pounds off Austin Healey 17
Keoke 1966 AH BJ8 on eBay Austin Healey 18
L BJ8 Batteries Austin Healey 8
pkmh Front Spring Removal For BJ8 Austin Healey 8
M Wanted Bj8 left front wing Austin Healey Classifieds 3
