TR6 Oil Pressure Gauge
Geo Hahn
I am going to use a TR6 (mechanical) oil pressure gauge on a non-TR British car (one that comes with a notoriously unreliable electronic sender and gauge).
Who can tell me what threads are on the back of the TR6 gauge for the oil line?
Also - I see the Moss catalog shows an adaptor from the block to the line (shown on this page). Can someone tell me the threads that are on the block side of that adaptor?
I suspect that adaptor goes from BSPT to NPT but want to confirm to hopefully order the right bits the first time around. Thanks.
dklawson
The original Smiths setup used a leather or fiber sealing washer between the gauge and a (more or less) straight threaded female fitting on the end of the oil tubing. Regardless of what the threads are both in the block and on the gauge, you will have no trouble using 1/8 NPT fittings to connect it. While you can use Teflon tape on the threads of the gauge before attaching the 1/8 NPT fitting, I prefer to use Teflon pipe dope instead. The tape can release threads of material that float around near the tiny hole supplying the gauge. Again, 1/8 NPT will be fine with some sealant on the threads.
The aftermarket gauge installation kits will come with some 1/8 NPT male and female compression fittings. The nylon tubing kits are OK for a few years but they can be delicate. There are also copper tubing gauge kits. They are nicer but for longest life you should loop the excess copper tubing into a coil between the engine and firewall to absorb vibration and engine movement. For a more permanent (and more expensive) hookup, Longacre sells 3 or 4 braided oil line kits at Summit Racing that are affordable. Visit Summit's web site and in the search field enter "Longacre gauge supply" to find the hose kits.
PatGalvin
Geo, Ted from TSI will make you a nice custom SS Braided Hose for this application. I have one for my TR3 that works great. Also, don't forget the little leather washer. My gauge leaked without it, no matter how much Teflon tape or pipe dope I used. Good luck!
Pat
dklawson
Sorry to here your fittings leaked Pat. I have not had any problems using the NPT fittings and pipe sealant with Smiths gauges. The leather washer is a must if you are going to use the OEM type fittings. I am not sure if Seven has them to go along with the hose that Geo provided the link to. If they don't I believe someone on this board said Moss had them.
EDIT: I checked Moss. They have a number for the leather sealing washer but it is marked "NA". On the Seven web site they don't appear to have the seal either but they suggest using a nylon or soft metal washer in place of the original part.
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
Superwrench Oil Pressure/ Water temp Gauge Austin Healey 17
JimTR4 TR4/4A Oil pressure gauge hose Triumph 5
T Oil Pressure Gauge Not Reading Spridgets 8
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
K TR2/3/3A Oil pressure gauge readings? Triumph 9
M TR2/3/3A Oil pressure: the gauge? Triumph 4
Rut MGB Oil pressure gauge leather washer MG 13
maxwedge5281 oil pressure gauge line...urgent!!! Austin Healey 10
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
M TR2/3/3A Reading oil pressure gauge Triumph 3
K GT6 Spitfire oil pressure gauge readings? Triumph 4
pkmh Reinstalling oil pressure gauge in a BJ8 Austin Healey 4
P Mounting Bracket for Bugeye, Water/Oil Pressure Gauge Spridgets 5
NardisCNC Oil Pressure Gauge Questions..... Spridgets 8
JimTR4 Electric oil pressure gauge Triumph 20
Dougal BN1 Safety Gauge [oil pressure/water temp] number Austin Healey 4
T Oil Pressure Gauge braided line failure Austin Healey 6
S TR2/3/3A TR3A Oil Pressure Gauge Leather Gasket ?? Triumph 11
D Oil pressure gauge flex hose. Spridgets 29
Stewart Removing the rectangular oil pressure gauge MG 5
sail Oil Pressure Gauge Stuck Triumph 4
60TR3A Leaky Oil Pressure Gauge Triumph 14
E Oil Pressure Gauge Pipe Fitting Spridgets 7
E Bugeye Oil Pressure Gauge Spridgets 5
tmc oil pressure gauge and line Triumph 5
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
hondo402000 TR6 TR6 71 Oil pressure gauge Triumph 3
R Oil Pressure Gauge MG 3
W Oil pressure pipe - gauge to flex hose P/N 2A5640 Spridgets 10
RedTR3 TR2/3/3A TR3 Oil Pressure Gauge Hose Triumph 3
T 1500 oil pressure gauge leaking Spridgets 6
RickB Oil pressure gauge scared me last week... Spridgets 3
M Oil Gauge reading high pressure MG 3
RickB Dual temp / oil pressure gauge - how to remove? Spridgets 18
Atrus Oil Pressure fitting thread size [calibrate gauge] Spridgets 15
M Oil Pressure Gauge Triumph 0
