'nother ignition question
Morris
Do the plugs fire when the points close, or when they open.
leecreek
open
Sarastro
That's right; when they open.
It works like this: when the points are closed, the current in the primary of the coil reaches a more or less constant DC value. When the points open, the collapse of the magnetic field around the coil generates a large voltage across the coil. If there were no capacitor, you would just get a huge "spike" of voltage, which would probably arc across the points, frying them, and be too short to light up the plugs very well. But, with the capacitor, you get an AC current in the coil, which dies out over a much longer period of time. The peak voltage across the coil is also much lower--but still a couple hundred volts, if I remember correctly. (So, keep your fingers off those "low voltage" terminals; they ain't just 12 volts!) I've measured this on my bugeye; the AC is about 10 KHz and lasts about 0.8 millisecond before the spark extinguishes.
DrEntropy 'nother Alfa Spotted 1
DNK Nother possibility Lotus 8
LBCs_since_1988 MGA 'nother MG Project ['58 MGA] MG 8
DNK 'Nother Dreaded Sound Deadening Question Triumph 19
ronzet Soo, OK... 'nother question about Moss and Chrome MG 70
R Nother scam? Austin Healey 7
Morris Nother Cam Question Spridgets 3
J TR6 'nother question about the diff on a tr6 Triumph 9
DrEntropy 'nother progress shot: Other Cars 17
jlaird Nother question - springs, rear Spridgets 12
tiga2 ' nother newbie Austin Healey 7
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 9
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
