Nother question - springs, rear
jlaird
What if anything is between the spring leaves?
I for sure need to take mine apart and clean and paint if nothing else. see no broken leaves so........
jlaird
jlaird
Got it, another job for rustolum. Bear metal, prime and paint. Good deal. Now if I can just get the darn things off.
RobSelina
on 'modern' leaf packs they have plastic pads under the leaf ends to allow them to flex easily, but in this case, just add some grease...
RobSelina
[ QUOTE ]
Don't use grease, it just collects dirt and makes a real abrasive mess. Use Graphite.
[/ QUOTE ]
can't argue with that.
msoylemez
You mean use graphite between all the leaves? Or just on the end (where it bolts into the spring pan)? Is graphite readily available from Pep Boys?
Thanks.
jlaird
jlaird
Is at ACE and Home Depot and Lows.
tony barnhill
Great Pumpkin - R.I.P
Why not put some of the plastic strips off a modern car on them?
jlaird
jlaird
Think I will take em to my favorate spring builder. Tony, you there? LOL
jlaird
jlaird
I would think the whole works, but then thats just me. After all they got to move to work.
GB1
I concur, the next time mine come out, probably in a month to install a wedge and take out another leaf, I will be doing the same.
DNK 'Nother Dreaded Sound Deadening Question Triumph 19
ronzet Soo, OK... 'nother question about Moss and Chrome MG 70
Morris Nother Cam Question Spridgets 3
J TR6 'nother question about the diff on a tr6 Triumph 9
Morris 'nother ignition question Spridgets 2
DrEntropy 'nother Alfa Spotted 1
DNK Nother possibility Lotus 8
LBCs_since_1988 MGA 'nother MG Project ['58 MGA] MG 8
R Nother scam? Austin Healey 7
DrEntropy 'nother progress shot: Other Cars 17
tiga2 ' nother newbie Austin Healey 7
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
