non Healey tires
Keoke
Yes TH I had a set put on my Ford Escort they turned out to be great--Fwiw--Keoke
gonzo
TH,
Installed Hankooks Ultra HPs on the Audi S4 about 10 mo.s ago and very happy with performance. Exceeds Dunlap and Pirelli for high speed stability and overall drivability. Buy online, you know, The Rack, and get better pricing with manufacture rebate about the cost of one tire. Well worth the change and you'll like the chunky tonka truck-like off-road look on the 4 Runner.
Apologies for not posting for a long while, we just moved to SOCAL (Orange County) and settling in. More to follow.
Good luck with tire purchase.
GONZO
Jerry
We put them on a Lemon's race car and ran about 600 laps at Infinion. They were great. We bought them because they were soft and would stick to the track. I must admit we wore out the fronts in the two day race, but that was with the pedal to the metal the whole race. IE: we got about 8 mile to the gallon in a Toyota! It had a turbo and I think it was on the whole race. I would buy the tires again.
Jerry
tahoe healey toyo tires for non healey Austin Healey 6
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
Ed Kaler Non-Healey but Healey person Austin Healey 3
timbn2 shipping a non-running healey???? Austin Healey 3
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
Fanch00 Non-Overdrive Benefits? Austin Healey 10
Celtic 77 MGB Non working tach. MG 4
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
J TR2/3/3A Adjustable vs non Adjustable wheel Triumph 0
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
AUSMHLY SU Damper Cap Vented vs Non-Vented Austin Healey 25
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
C Non-Adjustable steering column questions Austin Healey 14
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
HighAltitudeTR3 TR2/3/3A Synchro in a non synchro? Triumph 19
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
maxwedge5281 Trafficators, Adjustable vs. Non-Adjustable Austin Healey 14
Jim_Gruber Non LBC but saw my first Civic Type R Yesterday Spridgets 24
Zitch TR4/4A OD Addition to a Non Over-Drive Transmission - my attempt Triumph 11
Rut Interesting non Spridget Spridgets 3
NutmegCT The non-garage garage Restoration & Tools 22
Marla TR4/4A Ballast or Non... Triumph 6
R TR2/3/3A Non Triumph cooling question Triumph 8
B Posting non you tube video? FORUM Navigation Questions 3
Jim_Gruber Saw my first NSX in the flesh - non lbc Spridgets 2
Jim_Gruber Saw my first NSX in the flesh - non lbc Spridgets 0
C TR6 Non-start diagnosis Triumph 9
GTP1960 TR2/3/3A Resistor plugs vs. non-resistor plugs? Triumph 6
nevets interesting piece in the NYT about collector car non-restoration Austin Healey 5
vette Detergent/Non-detergent Austin Healey 19
AUSMHLY Best 7" non sealed headlamp Austin Healey 19
Jer an Latest from a fellow LBC guy - new non LBC purchase to share Spridgets 11
CJD TR2/3/3A Adjustable vs Non-adjustable Control Heads Triumph 4
P I need a non-working electric tachometer for parts Spridgets 0
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
vette Detergent or Non-Detergent, Trans/ OD Austin Healey 7
Boggsy64 MGB Starter - Non starter? MG 16
K TR2/3/3A Trunnion spindle cotter pin hole non existent! Triumph 9
Zitch TR4/4A Non OD rear transmission seal replacement Triumph 1
S WTB: Non-Adjustable Horn Button for a 3000 Austin Healey 6
